Results 1 to 8 of 8
Thread: Intex 12x24 Doesn't circulate surface water well
    Jun 2014
    Baltimore, MD
    18
    Hello!
    Hopefully someone can help me out. I have a 12'x24' Rectangular Intex Ultraframe pool and the original floating filter / pump / water return that came with the pool and it doesn't do a very good job at circulating the surface water so I always have pollen and other debris floating on the surface. Do anyone know of anything I can purchase or any fairly easy DIY solutions? I was thinking something that returned the water at more of an angle towards the end of the pool may help get the water circulating better. Any suggestions are appreciated!
    Thanks!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Intex 12x24 Doesn't circulate surface water well
    Hi there and welcome to TFP...
    Many people, myself included have "modded" or hacked our pools and added a Hayward Through The Wall Skimmer.... Here is the link to the exact one you want to look at... http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    There's heaps of threads on here that can show you how to add the skimmer, you just use the google search function in the top right hand corner, and you will have to make some adjustments to your plumbing.... What sort of filter came with your pool?
    This is quite a popular filter that will probably do a better job on your pool.... Your pool is almost twice the size of mine... I too have a rectangle intex pool 18 x 9....
    http://www.amazon.com/Intex-650-Gall...rds=intex+2650
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2014
    Baltimore, MD
    18
    Does the Hayward Through the Wall Skimmer seem to circulate the water better or clean the water surface better? I get a lot of "dead spots" on the corners of my pool and just in general the surface doesn't get cleaned off like I hoped it would. I really want to find a way to get better water circulation on the surface and the whole pool. I was considering The Circulator
    http://www.amazon.com/Circulator-100...the+circulator
    Orlando, FL
    690
    Have you aimed the return eyeball as far down as possible? That helps a lot with circulation. That having been said, I encourage you to add the Hayward Skimmer. It is a modification that you will not regret and there are many threads/people on the forum who will help you do it properly. It seems to be very cheap and easy to accomplish.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jun 2014
    Baltimore, MD
    18
    I have tried changing the eyeball but my problem is "dead spots" on the surface of the way wear pollen and other debris build up because of poor surface circulation. I am thinking of trying The Circulator along with getting the Hayward Skimmer I seem recommended on these forums so much. I am also thinking of adding a solar cover (http://www.vminnovations.com/Product...-Tube-Set.html). Thanks for the suggestions.
    Jun 2012
    Michigan
    154
    Is the water always slow coming out of the return? if it's just after it's been running a while, one other thing to check, if you have a lot of cottonwood seeds and other stuff floating through the air this time of year and an over the wall skimmer basket, where the hose from the skimmer basket goes into the wall, remove the hose, unscrew that part, then clean off the grate/grid, its probably clogged and not letting enough water get through.
    May 2014
    Toledo, Ohio
    7
    Are you still using the stock pump that came with your pool?
    I found that the stock Intex pump just did not seem to move enough water. When I upgraded the pump to the next size up last year I saw a definite up tick in the output fron the returm. It wasn't until this season, when I got rid of the Intex Flex Hoses and the Intex Plungers, that I really saw a discharge volume increase. Now I can adjust the return eye and literally make the return arc over the surface and create a a visible current. The change really makes the Hayward Thru-Wall skimmer work.
    Intex really does make a great pool, its' just the small low volume stock pumps and accessories, which come with many of the pools, that make the pool seem sub-standard.
    Good luck with your mods.
    Pool: 5000 gal, 16'x 48" (AG) Intex Ultra Frame, Intex 1500 GPH Filter Pump 635T (cartridge), Hayward Thru-Wall Skimmer SP1091LX, 1.5" PVC Plumbed (Rigid & Flex), Heater: Aquah 10L Propane Outdoor Tankless Heater (68,200 BTU), 1/2" PVC plumbed, Intex 1000 GPH Filter Pump 637R (no-cartridge). Hayward Return SP1023 Climate/Location: North West Ohio
    Jun 2014
    Baltimore, MD
    18
    @RazzleyDazzleyGuy
    Thank you for the suggestion. I think I will start with upgrading the pump and then going for a Hayward Skimmer after that. See if those two help me out. I am using all default parts with the pool and it is a few years old now. Problem is my pool sits about half covered by a large oak tree. The branchs are a good 20" above the surface of the pool but I get a lot of debris out of the tree that just floats around since the floating skimmer and stock return just can't circulate the water enough.
