Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: My results with new TF-100
    Jun 2014
    Fulton, ms
    32
    My new TF-100 got here today!
    FC 5.5
    CC 1.5
    PH 7.4
    CH 250
    TA 135
    CYA 25
    CYA level was directly between 20 and 30, so I assumed CYA of 25.
    Starting SLAM. Pool math said shock level is 10, so I added 28 oz of cal-hypo 65% to bring the FC level to 10. Waited about 30 mins while scrubbing walls then checked FC & CC again.
    FC 13.5
    CC 1.5
    Here are pictures from today:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: My results with new TF-100
    How exciting! The Junior Scientist Playset is here!
    You are aware that Cal-hypo is going to raise your CH level as it raises the FC level, right? The FC will disappear, but the CH won't. If it's leftovers you're using up, fine. Otherwise, buy liquid shock or plain bleach in the future. Also note that Cal-hypo can cause cloudiness for a day or two after it's been added. It also can react unpleasantly with certain algaecides, if the pool store suckered you into buying any in the past.
    Jun 2014
    Fulton, ms
    32
    After the 50lb bucket is used up, we will switch to liquid chlorine. We still have about 15 lbs of trichlor that we were afraid to use because the pool store keep telling us our CYA was 100. We were pool stored into buying copper algaecide. We added about 20 ounces of it a little over a week ago. What kind of unpleasant reactions?
    Richard320's Avatar
    Jan 2010
    18,966
    Quote Originally Posted by Jdaher View Post
    In an extreme case...http://www.troublefreepool.com/threa...rgs-plus-Green
    38,235
    Don't keep using a product that is going to take your CH out of range. Once it gets too high, you will have to drain and replace water.
    Clearly you CYA is not too high, so you could use some of the Trichlor (if you understand all the effects), although I would wait until after you finish the SLAM process using liquid chlorine.
    Jun 2014
    Fulton, ms
    32
    Here is what the pool looked like two weeks ago:
    1 week ago:
    Jun 2014
    Fulton, ms
    32
    3pm
    Fc-11.5
    Cc-1.5
    Brushed and Vacuumed pool
    5:30pm
    Fc-10
    Cc -1
    38,235
    Test again in an hour or so as you FC will have dropped below SLAM level and you will need to raise it back up. At least the CC appears to be dropping
    Jun 2014
    Fulton, ms
    32
    Added 32 oz of cal hypo 65% at 6:30pm to bring fc level to about 15 according to pool math.
    Tested 7:30 pm
    FC - 20
    CC - 2
    Why did FC go up so much? Should CC go up at any point during this?
    Richard320's Avatar
    Jan 2010
    18,966
    Tested 7:30 pm
    FC - 20
    CC - 2
    It probably didn't mix well. If you hit the pool with the brush and get some cross-currents going, it will mix better.
    CC will be all over the place during the SLAM. At some point it will go down and stay down. You only need to worry about it after the water is clear. If the water is clear and the CC is less than .5, then you set the alarm extra early and do the overnight test. Until then, don't worry if CC bounces around.
    Jun 2014
    Fulton, ms
    32
    6:45am
    FC 14
    CC 1.5
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    6 FC loss overnight isn't too bad for what stage you're at with the SLAM. Keep at it! And keep posting pictures when you can.
    Isolated Spa - 345 Gallons
    Jun 2014
    Fulton, ms
    32
    Quote Originally Posted by JVTrain View Post
    It probably wasn't mixed up all the way like Richard said so it was probably even less fc loss overnight.
    Today around 11:
    About to go test
    Jun 2014
    Fulton, ms
    32
    12pm
    FC 11
    CC 0.5
    Added 12 ounces cal hypo 65% to bring level to 13 in case of sun loss during the day.
    38,235
    You did note the statement earlier that the cal-hypo might be contributing to your cloudiness ... right?
    Jun 2014
    Fulton, ms
    32
    Yes, when we run out of the cal hypo, we will switch to liquid chlorine. Will adding DE to my sand filter like in the how to section help with the cloudiness?
    Jun 2014
    Fulton, ms
    32
    8:30pm
    FC 14.5
    CC 1.5
    I also added DE to the sand filter. Only took 1 cup to raise pressure by 1 psi. Followed directions posted on here.
    Jun 2014
    Fulton, ms
    32
    5:30 am
    FC 13
    CC 1.5
    Filter pressure rose from 16 psi to 20psi after adding the de (9 hours)
    Added 20 ounces of cal hypo 65% to bring fc to 16-17. Should be sunny today. I figure a 30-40% loss should keep me close to or above 10 fc.
    Jun 2014
    Fulton, ms
    32
    3:30pm
    FC 12.5
    CC 1.5
    Added 22 ounces of calhypo65 to bring FC to 16 and scrubbed everything.
  20. Back To Top    #20
    Jun 2014
    Fulton, ms
    32
    7pm
    FC 17.5
    CC 1.5
