Results 1 to 10 of 10
Thread: CYA and Chlorine Levels
    Jul 2013
    Long Island New York
    63
    Through years of trying to get rid of algae by shocking (no longer do that by the way) my CYA level is upwards of 100. I keep my free chlorine level at the recommended level for the CYA and the water is absolutely sparkling crystal clear. I know I have to dump water and refill to fix the problem but would like to hold off a bit since right now the pool is seeing quite a bit of use. My question is would a free chlorine level of around 10-12 cause any harm to the liner or anything else?
    38,274
    Re: CYA and Chlorine Levels
    As long as you keep the FC at the recommended ranges based on the CYA, then you are not putting the liner at risk.
    But, remember when FC > 10ppm, the pH test is not valid.
    Jul 2013
    63
    I did not know that! Maybe that is why my PH is reading a bit high sometimes?? Shall I make sure the FC level is below 10 and then do a PH test from now on?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Quote Originally Posted by ChiefRob View Post
    That is one solution. It gets old fast, though.
    I just finished draining about 6" out of my pool to lower CH. At an average depth of 60", that's 10%. That much water can be refilled in a couple hours and won't totally mess up the chemistry. Do that a few times and you'll have CYA down to something useful.
    Jul 2013
    63
    Good idea, I will give that a shot. Actually we had horrendous rains here on Long Island recently. My water level is quite high, I will reduce it and fill it back up and see where it gets me.
    38,274
    Have you done the diluted CYA test? Starting with 50/50 mix of pool and tap water and doubling the CYA reading? Give you a better idea of how high your CYA actually is.
    Jan 2013
    Houston, TX
    1,079
    If there is a big rain coming you can also do some rainwater harvesting:
    http://www.troublefreepool.com/threa...vesting-and-TA
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jul 2013
    63
    jblizzie, so if i dilute the pool water 50% and my cya is down to 50 instead of 100 that would mean i have to replace roughly 50% of the pool water correct?
    38,274
    I don't understand. If you use 50% pool and 50% tap water, then add the reagent and test. Then whatever reading you get, double it and that is your CYA level.
    If you happen to read 50ppm, then you CYA is around 100ppm and to get to the recommended range you would need to replace 50% of the water (this amount of water replacement has nothing to do with the fact that you use 50% pool/tap water)
    Jul 2013
    63
    Sorry I was a bit confusing. I tried to basically spit out exactly what you said! I will be doing that test this afternoon. Thanks!
