Thread: Eyeball
    Jul 2011
    Corinth, NY
    76
    Eyeball
    Anyone here ever have a hard time adjusting the eyeball on their return? I have it almost where I want it to be but I want it adjusted a bit more.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Eyeball
    My return eyeballs are sticky as H E double-hockey sticks. Two of them are easier to position if I loosen the outer retaining ring and then move them. The other I have to jimmy a flat screw driver inside the eyeball and lever the eyeball to where I want it. I'm going to find a piece of dowel that's a bit larger than my return openings and taper the end. Then I can push that into the return hole and more easily maneuver it.
    Isolated Spa - 345 Gallons
    Jun 2013
    East TN
    309
    Re: Eyeball
    You could just make you one. I did. Works great for circulation. It will turn 360 degrees pointed up, down or sideways. It only costs a couple dollars to make.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
