Results 1 to 11 of 11
Thread: 5 Minute Temporary Ladder Installation with Photos!
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    I hate this ladder, it is too narrow and it's 20 years old.
    If you are like me you have too many projects going at once so sometimes "temporary" really means something will be around for years and years and...
    (here come the photos)
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Re: 5 Minute Temporary Ladder Installation with Photos!
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    It is so cold out! A few days ago we hit 95 and now, brrrr. The pool is full of storm debris. I still want to play with my pool so I picked up some baby t-posts and a section of pipe from Lowes and threw this together. I doubled up the posts because the bitty ones are so flimsy and they fit snugly inside the pipe on the ladder handrails. I had the ladder on the deck portion of the pool (which is a J shape) but I felt it was too close to the slide. The opposite side of the pool is not buried so this is really the best location.
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Nice Idea!
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Thanks Waldog! .
    Looks better than it did in my head.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    That is a great idea... Well done... Love it...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    514
    I love how your pool looks..and great idea.
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    Pigeonlove, this has nothing to do with your ladder, but the fact your pool is in the ground. I ask this because I would like to buy a above ground pool and sink it about two ft down. Did you do that yourself or have it done. I have been told that not all above ground pools can be sunk into the ground. Just curious about your thoughts and anyone else out there. Not for sure how the ground is in Boise, but here in the DFW area of Texas it is like concrete. Black dirt and a lot of it.
    Bullzak_83 (aka Trey)
    Arl, Texas (home of Jerry world. Not by choice)
    18'X48" Intex Metal Frame
    W/Intex sand filter and Chlorine generator
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Hi Trey!
    I did do it myself! I can post some more pictures of how it is set into the ground in the next couple days. I dug out a small hill so the opposite side is not buried. The sod area by the ladder is the highest point of the hill. I don't love having sod there right up to the pool but for now it works.
    I was not worried about voiding a warranty because it was an old pool, I did my research so was looking specifically for a Doughboy because they are high quality pools and some models are designed to be buried. I also wanted to go with a buttressed pool. It is a fortress!
    In the early spring the soil here is easy to dig but as it dries it is like concrete. I dug out the area by hand. That was brutal.
    Anyway, I'll go out and take some pictures tomorrow so you can see how it is buried. Any moderately handy person can do this and I'd love to share my wisdom
    -Annie
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    I am basically a SAHM but I work a little outside the home and was on-call today. I didn't think I was going to be called in but I was so these are some pix that were already on my ipad from the other day.
    From my reading some people do a lot of additional prep before burying a pool. I think that how you go about it will depend on your topography. I didn't have a huge hill that might slide down and if my pool fails the water will run away from the house, conveniently down into the canal
    I just back filled with dirt and plenty of composted horse manure on top because I have an endless supply. I wrapped the bottom track of my pool all around with foil tape up about 8" mainly to keep dirt out of the track. I painted over the bottom of the wall on the buried portion. My buttresses are set with 2x more block and concrete than the manufacturer requires.
    My pool is still unfinished but so much fun to work on!
