Thread: Finally have the water level for filtration...excited to get up and running...Q's...
    Jul 2013
    Princeton, NJ
    26
    Hey folks,
    So I finally have enough water in my 24 ft above ground (13.5k gallon) pool to turn on the filter.
    Have a Hayward DE filter, 3/4 HP pump
    My pool was filled with my well.
    The pH is 7.8
    FC is...well, gone every day.
    CYA is 0
    I'd like to get in this thing as soon as possible. As I've been filling it over the last couple of weeks, I've been adding bleach and the water looks nice (stuff on top, due to no skimming, but good otherwise).
    I think, from everything I've read I want a pH around 7.5ish, a FC around 4 and a CYA of around 30...does this sound right?
    I'd like to get in and running as soon as possible. I've done some pool math, and have plenty of bleach, so that's covered.
    My questions are for the pH and the CYA.
    pH: I want to lower it a tad, right? So I need some dry or muriatic acid to lower it a bit. Not sure if I should go for one or the other, but I think I need to hit a pool store because I need cyanuric acid anyway. Is there a pro/con for one over the other? Would I want to up the CYA and see if the process lowers the pH?
    CYA: Is there a negative to using liquid (seems much quicker...ie in the water quicker) over solid?
    Thanks!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,565
    Re: Finally have the water level for filtration...excited to get up and running...Q's
    FC to 4--now! PH to 7.5 by using liquid muriatic acid. CYA to 30 using Walmart HTH brand--granulated, Liquid cya is much too expensive. See the chlorine /cya chart in pool school.
    Jul 2013
    Princeton, NJ
    26
    Thanks for that.
    So, the HTH brand @ Walmart looks to be 15 oz for $15ish...and poolmath says I need ~56 oz. So, that's be 4 of those cannisters or $60. For liquid it says I need 140oz. and a gallon is $25...so I'd have to buy 2 gallons, which would be $50.
    Am I missing something?
    May 2014
    NYC
    47
    Quote Originally Posted by SubliminalME View Post
    Thanks for that.
    For Liquid you have to see what % of CYA it is. Some of them are not 100% CYA, so you have to adjust your numbers.
    For example, if it was 50% by volume CYA, then you would need double.
    Someone correct me if I am wrong but that was my understanding of liquid CYA.
    12' x 18' Oval Above Ground Pool (buried 2')
    Manufacturer states ~5,000 gallons
    Pentair CC75 Cartridge Filter System 1-HP Opti-Flo Pump
    Bleach Chlorination Method
    Aquabot Junior Vacuum
