Thread: A&A low-profile infloor cleaner valve - experiences?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Hi all,
    I've just completely worn through a set of gears in just 2 years. I know some other folks have the same system, is this the normal lifespan for yours? It makes me wonder if something is getting through the filter and grinding them up, though I've never noticed anything coming through.
    Gears aren't that expensive, but it makes me wonder.
    The valve looks like this:
    Wildcat's Avatar
    Jun 2013
    309
    Re: A&A low-profile infloor cleaner valve - experiences?
    I didn't answer because I was not sure what brand I have (I am not original owner). Pool was built around 2005. I was ignorant and it took me a while in around 2011/2012 to realize not all my heads were working. I think mine is a higher profile, older model but I looked up the replacement parts for A&A and it looked like what I purchased.
    So mine lasted somewhere in the 5-6 year range and I ran it a lot of hours each day with an old single speed pump.
    I replaced almost the whole thing and it was a pain because my piping meant I had to cut and replumb as there was no clearance. The next time it happens I may just have all the piping reworked. Hope this helps. It does seems yours failed prematurely based on my single example
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Oct 2009
    3,899
    Yeah, yours has a different style of gears that are more compact and possibly more durable. Just curious.
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by Melt In The Sun View Post
    Is there a warranty on the gears?
