Thread: Algae Blooms with FC
    Jun 2014
    Austin/Texas
    5
    I am new poster to TFP, but have been following all the threads for a year now and using my own test kit.
    After a 12 inch rain storm last year, I started having some problems.
    I found some slimy stuff on the walls that brushed away. It appeared to be gray, but I have gray plaster so maybe its light yellow. I brought the pool up to MSL for a couple days, brushed and removed the lights from their nooks. After a couple inch rain, I noted some cloudiness and found the same gray slimy material that brushed away. Treated again at MSL, this time being more careful in the brushing and opening up the light nooks for several days. Passed the overnight FC test and let it come back down. After 2 inches of rain this week, I immediately brought up to regular shock level, but saw the pump pressure heading up this week and noted the start of some cloudiness this morning. However, can not find any evidence of slimy material anywhere in the pool. I have a SWG and have not let the Chlorine below 4 since opening the pool.
    The chemistry of the pool this morning was (I have brought it up to FC of 32 now). Anyone have additional suggestions?
    FC: 4.5
    CYA: 50 (have not taken to 70 since that makes it harder to get to shock levels)
    PH: 7.5
    TA: 900
    GPete
    20,000 gallon pool, plaster, SWG
    Jan 2013
    Houston, TX
    1,079
    Re: Algae Blooms with FC
    SLAM the heck out of it (looks like you understand the maintain) until it is clear and you pass the OCLT. In the past have you done an OCLT to make sure you had killed all of the organics?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jun 2014
    Austin/Texas
    5
    The first time no (ran our of test stuff), second time I think so which is why this time is troubling. I will make sure I pass this time.
    GPete
