Thread: Should I SLAM after each heavy swimming?
    Oct 2013
    Houston, TX
    22
    Smile Should I SLAM after each heavy swimming?
    Hi,
    So we had a big party over the weekend with heavy swimming of 15 kids. I added extra 2-3 ppm of liquid chlorine right before the party and a little right after. My current FC reading is at 8 ppm which is slightly above the Target FC (7 ppm) and TC level is always at 0 ppm. Long story short, do you guys normally SLAM after such heavy swimming? Is it necessary to SLAM? Or as long as I can maintain the target Level, I'm safe?
    If I have to SLAM, does it mean I have to bring up to Shock FC level which is 24 ppm? I can't seem to find cheap deals on liquid chlorine around here so usually cost me around $20 for SLAM process..... try to avoid unnecessary step here if possible.
    Re: Should I SLAM after each heavy swimming?
    No, there is no need to SLAM after a pool party. I would bring FC up to the high end of the normal range, but no need to do the whole SLAM process.
    When you say "TC", I suspect you mean "CC".
    Oct 2013
    Houston, TX
    22
    Thanks for your quick reply. Yeah, I meant the total chlorine, a.k.a. combined chlorine. So I guess we are good for now as my FC is right where it should be.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by newbie_pool View Post
    CC is NOT TC
    TC = FC + CC
    From ABCs of Pool Water Chemistry in pool school:
    Combined chlorine is an intermediate breakdown product created in the process of sanitizing the pool. CC causes the "chlorine" smell many people associate with chlorine pools. If CC is above 0.5, you should SLAM your pool. CC indicates that there is something in the water that the FC is in the process of breaking down.
    CC is bad and should be close to 0 in a properly sanitized pool.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Oct 2013
    Houston, TX
    22
    Quote Originally Posted by svenpup View Post
    CC is NOT TC
    TC = FC + CC
    Thanks for your clarification. I am always confused between those two. My CC level is 0 when I did the test so even though with heavy swimming, it looked like I am safe as long as my FC and CC are at where they should be.
    Jun 2014
    Boca Raton, FL
    101
    I'm new here, but I just cleaned up my pool, so I feel empowered to give advice. Take it for what its worth...
    I would perform an OCLT a few days ahead of the big swim. That will tell you if you have an existing problem, and give you time to fix it if its not a major problem. Then I would adjust or allow FC to settle to the high end of goal range as suggested above.
    After big swim, perform an OCLT test that night, and react accordingly. Hopefully, all will be well, and you can keep up with routine maintenance and no SLAM will be required.
    jim
    16x32 DiamondBrite kidney, 12,500 gal. (circa 1985) 3/4hp Hayward SII, Harmsco BF84, Taylor K-2006, Hayward SwimPure Plus / Tcell-15
    Boca Roton, Fl. USA.
    prior 17k gal. vinyl, Sand filter
