Results 1 to 12 of 12
Thread: Best variable speed pump??
    Aug 2010
    Columbia, SC
    96
    I have the hayward Pro Logic controller with salt system and I need to replace my pump assembly. I am looking to upgrade to a variable spped pump. What pump will interface with this system the easiest? I have a 20000 gal pool and a water feature. no polaris output or other accessories... (Not put in by my pool builder for some reason).
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Best variable speed pump??
    What's your electric cost. If it's less than .30 KWh you may be better served with a 2 speed motor/pump. If the pump portion is ok, it's easier to just replace/upgrade the motor.
    Bob
    Aug 2010
    Columbia, SC
    96
    Unfortunately the pump is shot too. I have to upgrade the whole assembly. Not sure of my kWh cost. I will try to look that up.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The EcoStar is probably the best VS to pair up with the ProLogic.
    But SC gets quite a bit of lightning so you will want to make sure you budget in a surge/lighting protector. With the extra pump cost, you will probably find that the lifetime cost of the VS route is going to be much more than a simple two speed. Although you may going with a VS for other reasons too.
    Mark
    Aug 2010
    Columbia, SC
    96
    The ecostar is the one I have been looking at. I currently have a 1 1/2 hp single speed pump. I doubt that my pool builder really figured out the requirements on my pool. He actrually went through three pumps putting it in because he could not get them to prime. He originally had a 3/4 hp pump on the pool and a 1 hp on the waterfall.
    How can I cvcalculate which pump I need with my pool size and waterfall?
    mas985's Avatar
    Pleasanton, CA
    11,737
    How big is the waterfall and/or do you know how much flow rate it requires?
    How far is the pump elevated above the water line?
    A 3/4 HP pump should have worked fine but it depends on the above questions.
    Mark
    Aug 2010
    Columbia, SC
    96
    Quote Originally Posted by mas985 View Post
    It is a fairly large waterfall. Not sure of the flow rate. However it has always seemed underpowered. The pump is about 3 feet above the waterline.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Did the PB put in a check valve before the pump? With that elevation, he should have to help with priming.
    Also, what size pipe did they use for the waterfall, suction and pressure?
    Mark
    Aug 2010
    Columbia, SC
    96
    2" pipe for everything. I put in a check valve after he finally gave up. This has helped quite a bit with priming. I am going to clean up the plumbing in general while I put in the new pump.
    We are about to go to court as the water feature was never finished, along with quite a few other issues never completed.
    Apr 2011
    Murrieta, CA
    2,360
    Mark is definitely this forums expert when it comes to pump matters. I'll defer to him.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Given that the waterfall was somewhat less than inspiring even with a 1 1/2 HP pump, the VS might be a good choice so you can get some extra flow out of it and easier to optimize. But just make sure you get lightning protection.
    Mark
    patrick3229's Avatar
    Feb 2012
    258
    Another option could be the Tri Star Variable Speed Pump which is specifically designed to work with the Pro Logic Controller Part # SP3200VSPND http://www.hayward-pool.com/pdf/lite.../LITTSVS14.pdf This is basically the same as the normal Tri Star Variable Speed Pump but does not come with a controller on top of the pump as you will be using the Pro Logic to control the pump. Because this pump does not have the controller on the pump it costs a little bit less.
