Thread: Sand Shooting in through Jets! Help!
    Jun 2014
    Channahon,il
    1
    I have a Sta-rite crystal flo high rate sand filter and it's always worked beautifully. I know I broke it, 100% my fault, wondering what I need to do to fix it. I moved the handle from backwash to Waste without shutting it off. While doing so there was a very loud thud. I turned it off and started the filter because I assumed something broke and sure enough sand is coming out the jets, a lot of sand. I need advice on how to fix it quick.
    I'm having my boys (twin 7 yr olds) baseball team party Sat. and don't want to disappoint them. Thank you for any advice!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Sand Shooting in through Jets! Help!
    Hi, welcome to TFP! You need to take apart the multi-port valve and inspect the spider gasket. If it is torn or loose it will need to be replaced.
    Love TFP? Become a
    TFP Supporter!
