Thread: Above ground overlap liner - too tight? Or just right?
    May 2009
    Mn
    198
    Ok per the directions the liner is supposed to be slack on the wall. Not in our case, it is really tight around the top. The bottom seam seems to sit evenly on the cove all the way around the pool but the top is drum tight. Is is supposed to be like that?
    Also on one part the liner doesn't fully rest on the cove. Will it stretch once we add water? (And some sun?)
    We tried the vacuum trick to pull it tight but it just started to suck the liner into the vacuum and I was worried it would cause a permanent indentation. It did pull out the wrinkles just not in that one area it didn't pull it tight.
    My husband was sick of the project and put all the top rails on so taking it apart is not going to be fun.
    Your quick response is greatly appreciated.
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    Casey's Avatar
    SW PA
    10,457
    Re: Above ground overlap liner - too tight? Or just right?
    FILL THAT POOOOOOOOL!
    May 2009
    Mn
    198
    Thanks for the support. I went ahead and filled it (while it was warm and sunny out). Everything worked out just beautiful. I only have wrinkles on the bottom, none on the sides. The walls didn't even pull in like they show on the installation video.
    Casey- I have to say that your pool build project was our inspiration to do it ourselves. Thank you for your determination and hard work.
