Thread: The PoolCleaner 4x
    Sastocky's Avatar
    Mar 2013
    Jackson, Ohio
    22
    The PoolCleaner 4x
    My wife and daughters recently purchased me The PoolCleaner 4X.
    Our pool is an 18'x36', shallow 3', deepend 8'.
    Do any of you The PoolCleaner 4X or 2X ​pros have any recommendations on tips tricks or setups?
    Southern Ohio, 18'x36', 8'x3' deep, Vinyl, Hayward 1hp Super Pump, Hayward Sand Filter, Hayward AquaRite 25k SWG, 5-3'x8' Solar Panels, Hayward AquaSolar, Aqua Pro 137k Heat Pump
    Taylor K-2006, Taylor K-1766, Taylor SpeedStir, hth 6-Way with OTO
    Jun 2014
    Delray Beach, FL
    13
    Re: The PoolCleaner 4x
    I have the 4X and it's very self explanatory. The manual will tell you the proper tire rotation to make sure it's moving at a proper speed, you may need to adjust the hose end that goes into the VAC line. The front tires have a small nub on them so you can easily count the rotation (provided the pool is clear).
    So long as your pump is doing it's part, just drop in the PC and you're good to go. This is my cleaner of choice and I hope you like it.
    Only tip I would add, because the hose breaks down into multiple sections (great for storing) it's easy to drop the hose under the water and assemble one at a time to avoid the air filtering through the pump (either that or assemble the hose and then use a jet to push the air out).
    Lastly, as with all basic cleaner and hose knowledge, try to avoid having the cleaner in for 24-48 hrs after treating the pool with chemicals, and don't let the dog near those hoses (dog nails and chemical corrosion will result in small holes in the pump, which will slow it down and push air through your filter)
    Outside of that, my wife prefers to call it Fredrick, so you may want to name it to make it fun for the wife and daughters.
