Thread: Pool water tastes like I have my tongue on a 9 Volt battery.
    Loogootee, IN
    122
    I got my new pool set up and finally finished filling it up last night. (updated my signature line) I added 27oz of the HTH Stabilizer (CYA) per recommendation from the pool calculator. Ran the cartridge filter that came with the pool for 4hrs. (waiting for new sand filter system to come in) This evening, Although water is still cold, I decided to get in. With the kids splashing and I wrestling with them I obviously got a little water in my mouth. It tasted like a tin can metal taste or like when you test a 9volt battery with your tongue. It kinda threw me because, I filled the pool with city water. And my drinking water doesn't taste like this. Although I do have a water softner, not sure if the outside water spicket is inline with the water softner as well or not.
    After the kids got out for the night, And Before I put in the bleach for the first time,
    I tested the water and these are the results I got:
    PH 7.5
    Alkalinity 450ppm
    Hardness 50ppm
    No CYA test yet, waiting for my refill to come in as well.
    Any recommendations on what my Alkalinity should be?
    18ft x 48in Round Intex Ultra frame. 6,700 gallons.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Pool water tastes like I have my tongue on a 9 Volt battery.
    Ideal TA is in the 100 range.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Sounds like high Iron in the tap water. Get a glass from the outside faucet and taste it.
