Thread: Comparing Pool Store Tests
    Jun 2014
    Fulton, ms
    32
    Post Comparing Pool Store Tests
    Posted this in one of my previous threads, but I thought it was worth sharing on its own.
    Yesterday morning I got three sample bottles and took a sample to each of the three pool stores in my area. The sample water was taken exactly the same at the same time. All three pool store tests were done within an hour of each other. Here are their results:
    Code:
    Test 			Store#1		Store#2		Store#3
    TC 10 3 0.14 FC 10 3 1.25 TA 120 - 50 PH 7.5 7.6 7.2 CYA 20 100 0 CH - - 10 Copper - 0.5 -
    A clear indicator of why you cannot trust pool store testing... FYI, my TF-100 should be here tomorrow!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Comparing Pool Store Tests
    This one is getting saved alongside this thread: http://www.troublefreepool.com/threa...cy-in-readings
