Results 1 to 9 of 9
Thread: What is this blob?
    What is this blob?
    This was on the bottom of out agp, almost feels like wood pulp or lint. Same stuff I find on the skimmer sock
    24' AGP, 54" - 13,300 Gallons at 47".
    AquaRay Cleaner
    Hayward Swimpro Voyager Filter/2 Speed 2 HP Pump
    Casey's Avatar
    SW PA
    10,421
    Re: What is this blob?
    Well, I don't know what it is. I guess it really doesn't matter because it's not in the pool anymore right? Looks pretty gross though... yuck.
    Yeah but it's not the first time I've seen it. Looks like a cocoon in the water.
    AquaRay Cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Most likely some seed pods from trees.
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Yes, it looks like seeds from cottonwood trees. I know here in Michigan they have started to drop this week.
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    I was going to suggest owl poop but if you have cottonwood trees then that could be.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Looks like this, just taken out of my skimmer sock after one day.uploadfromtaptalk1402956123732.jpg
    Cottonwood? I don't know, but quite common for me this time of year.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    DeeMac's Avatar
    May 2012
    Munster, IN
    123
    THat is cotton ....we have it and it seems as if it is never going to stop blowing into my pool. This is a yard just around the corner from us.
    16 x 34 inground vinyl pool
    Hayward 1 hp super pump
    200s Hayward Sand filter
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Yep, either Cottonwood or Locust tree pollen, I've got it bad here right now too.
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
