Thread: Jandy Hi E2 will not fire
    Hi all I have completed my first winter with running my outdoor pool all winter long in Wisconsin. Thankfully it waited until last week for my heater to break and I was able to diagnose it down to the blower which had a bird in it. I cleared the bird and tried to fire it up by it will now not ignite and run. I am able to see the pilot light on and the blower starts per normal put when the gas valve opens it makes a poof sound and stops the gas and turns off igniter but the blower keeps running and it tries to cycle back on every 2 minutes with the same result. It did fire once last night after it did this for about 15 minutes but all day today it will not fire over. I also notice a brief one blink on the ignition control when it makes the poof and then it goes away. Any help will be much appreciated.
    Building year round use outdoor in ground pool in Wisconsin
    Re: Jandy Hi E2 will not fire
    Bump
    That is a complicated and expensive heater. I would recommend turning off the power and gas until you can get a qualified service person to diagnose and repair the heater.
    Support the site
