Thread: Air Blower Will Not Operate
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    Hi....Recently purchased a home with a poo/spa combination. Air blower didn't work, so I purchased a new Polaris QT blower (same made/model as original). Wired it up and it will not operate. New to the Aqua Logic controls - I verified that I have power to Aux 1, which seems to be the power source for the blower. Tester lights when Aux 1 power is on. Blower has no sound, nor vibration with Aux 1 powered on. Toggle switch is on.
    I hate to sound dumb, but what am I missing? Is there something in the Configuration Menu that's keeping it from not running? Any direction will be greatly appreciated!
    New Pool: Pentair Intelliflo VS Pump, Pentair Quad 100 DE filter, Pentair EasyTouch control system, Pentair IC 40 SWG, Pentair Mastertemp 400,000 BTU gas heater, Pentair ScreenLogic wireless interface, Spa, Polaris QT Blower, Polaris 9450 pool cleaner, Gunite w/ Pebble Tec, 10K Gallons
    Old Pool: david-and-kristy-s-pool-build-t8676.html
    Re: Air Blower Will Not Operate
    Test power at the blower. If you have power there then problem is with the blower. If you don't have power at the blower the problem is with the automations system.
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    Yes, I have power at the wire nuts. I'll have the blower checked.
    Thanks!
