Results 1 to 11 of 11
Thread: cloudy water coming from jets
    Jun 2014
    Monroe
    13
    Hi everyone,
    I am a new pool owner (new to the home, 7 year old pool)..I posted recently about balancing the water and you were all very helpful! Now, I have a question about our filter. Today, the pool jets started to pump out white, cloudy water and a cloudy film started to accumulate above the jets. Does anyone know why this is, or how to fix it? We have a Sta-Rite filter system (pictured below), and the psi is at around 10 right now -- I'm not sure if that is relevant or not.
    40 x 19 oval in-ground pool, average 4.8ft deep located in Monroe, CT
    chlorine feeder attached
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: cloudy water coming from jets
    Is that a cartridge or a diatomaceous earth filter?
    If it's DE, you probably have a torn grid and that white stuff is the DE blowing out. You'll need to open it up and see.
    Jun 2014
    Monroe
    13
    It's a cartridge system...
    Jun 2014
    Monroe
    13
    Here is a picture of what the water looked like with the filter running:
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Did you put any cal-hypo in your skimmer? Or DE perhaps?
    Jun 2014
    Monroe
    13
    No.. in the past few days we switched from using a chlorine tablet feeder to pouring liquid chlorine directly into the pool. We haven't put anything else in the pool and that's the only change we have made. Should I turn the filter off? The whole pool is slowly being covered with a foamy film now.
    Richard320's Avatar
    Jan 2010
    19,051
    You probably purchased some designer bleach -- splashless, high efficiency, scented, something.
    The thickeners cause foam. It will go away when you use normal plain bleach.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Any chance you've washed the cartridge recently and if so what did you use for a cleaner ??
    Solar Blanket, Well Water, Borax Added. 68
    Jun 2014
    Monroe
    13
    That's it then...I didn't realize some of the bleach I bought was high efficiency. I didn't clean the cartridge ever yet, so I think it must be the bleach. Is the extra suds harming my equipment or pool in any way? Will it fix itself if I just keep running the filter?
    Thanks for your help!
    Richard320's Avatar
    Jan 2010
    19,051
    I think it's just ruining the aesthetics of your pool.
    The splashless stuff foams up a lot, too, but nobody has reported liners dissolving. The high-efficiency stuff is new, so you get to be the guinea pig for us. Don't you feel honored?
    Jun 2014
    Monroe
    13
    oh great! I hope this stuff dissolves soon...fingers crossed!
