Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Bleed valve.
    Jul 2011
    Corinth, NY
    76
    Bleed valve.
    My filter does not have a bleed, so how would I bleed the air out of it?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Bleed valve.
    Can you provide us with a picture or more details of your filter? What's at the highest point of the filter?
    Jul 2011
    Corinth, NY
    76
    Re: Bleed valve.
    I have been trying to add a picture but it won't let me insert the image.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleed valve.
    You might need to go into "settings" at the upper right and then on the next page in the left column at the bottom "attachments" and delete any previous attachments you have. That might let you upload.
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2011
    Corinth, NY
    76
    Re: Bleed valve.
    It says I have no attachments.
    Jan 2013
    Houston, TX
    1,079
    Re: Bleed valve.
    Or try using tapatalk from you mobile device. No limits doing it that way
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleed valve.
    Have you been trying to "insert" it or "attach" it in the "go advanced" reply section ?? I use the attach.
    Jul 2011
    Corinth, NY
    76
    Re: Bleed valve.
    Okay there we go.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Bleed valve.
    Is there any chance that the filter is plumbed backwards? That would cause air to get trapped inside, and also correlate with your complaint in your other threads about dirt and sand in the pool.
    Jul 2011
    Corinth, NY
    76
    Re: Bleed valve.
    plumbed backwards?
    Richard320's Avatar
    Jan 2010
    18,988
    Re: Bleed valve.
    Quote Originally Posted by mkdsk101 View Post
    plumbed backwards?
    Yes. Are the hoses connected properly? If you try filtering with the flow going backwards, air will get trapped and the sand will get all disturbed and possibly blow back into the pool. Double check that. The ports are probably labelled. Just make sure the hose from the pump goes to the filter inlet.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleed valve.
    The out from the pump is going to the right side of the filter in the picture. The pressure gauge looks to be connected to the left side like it might be the inlet where the hose from the pump should be connected. I'm just guessing from looking at the photo but I'd check to see if the filter housing of that valve has a physical arrow showing flow direction or lettering "in" "inlet" ....
    What is the brand name of the filter and it's model #
    Jul 2011
    Corinth, NY
    76
    Re: Bleed valve.
    Yes it is all connected correctly.
    Jul 2011
    Corinth, NY
    76
    Re: Bleed valve.
    Just a lot of gurgling. Oh well. I hope to figure it out sooner or later.
    Apr 2011
    Murrieta, CA
    2,360
    Re: Bleed valve.
    It looks like on that setup trapped air will push out the exit port to the pool return. Yes, the model/manufacturer would be good to post.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleed valve.
    Getting back to your original question, because the outlet is at the top it would self bleed and that's why it doesn't have a separate bleeder. BUT, why did you want to bleed it ?? Did you just think you needed to or are you having a problem ??
    Jul 2011
    Corinth, NY
    76
    Re: Bleed valve.
    kiss4frog, my filter is gurgling and I can't figure out why. It is a Waterway Sand filter. 19 inch diameter, flow rate is 45.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleed valve.
    Is there any/much air showing in the cover of the pumps strainer ??
    Jul 2011
    Corinth, NY
    76
    Re: Bleed valve.
    The pump strainer does have a little empty space at the top while it is running but not a lot. Am I able to post a video here?
  20. Back To Top    #20
    Jul 2011
    Corinth, NY
    76
    Re: Bleed valve.
    Could it be the spider gasket in the Multiport (MPV) that is causing the gurgling?
