Results 1 to 15 of 15
Thread: Sand
    Jul 2011
    Corinth, NY
    76
    Sand
    Can old sand cause the filter to gurgle?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Sand
    No.
    Sand was already a million years old when it was bagged up to sell you. A few years inside your filter is nothing.
    Gurgling is probably trapped air. Check that the water level is high enough that the skimmer isn't creating a vortex and that the skimmer flapper isn't jammed somehow.
    Jul 2011
    Corinth, NY
    76
    Re: Sand
    I did check all of that and if anything the water is too high. I just can't figure it out.
    Jul 2011
    Corinth, NY
    76
    Sand
    How much sand goes in a 19 inch sand filter
    38,284
    Re: Sand
    What does the manual say? It has to be available online somewhere.
    Jul 2011
    Corinth, NY
    76
    Re: Sand
    Found it. 100 LBS
    38,284
    Re: Sand
    Jul 2011
    Corinth, NY
    76
    Sand
    How often should sand be changed in a sand filter?
    May 2013
    North East Ohio
    959
    Re: Sand
    Usually never....
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Jul 2011
    Corinth, NY
    76
    Re: Sand
    Oh I know you have to change it but was wondering is it every 3 or 4 years?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Sand
    No. You actually don't. You can deep clean it or acid clean it to remove excessive build up but actually needing to change sand is rare. Such as when converting from Bacquacil to chlorine.
    Isolated Spa - 345 Gallons
    Jul 2011
    Corinth, NY
    76
    Re: Sand
    I rather just change the sand rather the cleaning it. Sand is only $9.00 for 50 pounds and it takes less than 1 hour to change it. I had my pool since 2011 and I have changed it once already, today matter of fact. Just vacuum the old sand out and replace it.
    38,284
    Re: Sand
    And it takes 15 minutes and no money to run a hose through the sand to clean it.
    Re: Sand
    Merged a number of inter-related topics.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Sand
    Hmmmm, this is my third year same sand and I haven't even cleaned it yet! (But I just might this year! )
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
