Thread: pool base
    Jun 2014
    clinton
    25
    pool base
    Ive got a 24x52 doughboy and was planning on setting the frame on patio blocks to help make leveling eaiser, before i go much further, is this a good idea? After reading some other posts Im starting to worry about them breaking under the weight.
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Re: pool base
    The patio blocks will work fine, I have seen a couple posts about blocks breaking under Intex type pools.
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
    May 2014
    SW, MO
    58
    Re: pool base
    Doughboy recommend 12x12x2" patio blocks so make sure yours are thick enough. The thinner ones can snap under the weight.
    Jun 2014
    clinton
    25
    Re: pool base
    Thanks you guys, mine are 2" thick so should work great. Thanks again!
