Results 1 to 13 of 13
Thread: Salinity question
    Jun 2013
    Northern NJ
    123
    Salinity question
    Hi all. Had my aqua rite installed on Wednesday. Followed all instructions. Average salinity reads 4,200 and instant is 4,000. My % is set to 70. My FC yesterday was 1.0. My cya was 40. I know I have to get the cya up to 70. Should I turn down the % of salinity? Getting a little confusing
    Thanks
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    Nov 2011
    Magnolia Texas
    80
    Re: Salinity question
    My Hayward SWG works when the pool salt percentage level is between 2700-3400 ppm. Anything above or below that and it will shut off to protect itself. I think the 70% percent you think is the salinity level control is really the setting for how long the SWG cell is on.
    If you are in fact above the high limit (which is a good chance) for your type of chlorinator the only choice you have is to replace some of the water to bring it down. The only other thing I can think off is possibly you're getting a high salt reading because the salt was just dumped into your pool water all at once. If this was the case and the correct amount of salt was put in initially then it will come down in the next day or so. The pool calculator can help you with how much water you need to replace if in fact that is the case.
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    The % setting is run time percent. The SWG cycles on and off and you have to tune that percentage along with the total time the SWG is running per day (pump run time) until the pool is maintaining your target FC. There is an article in pool school describing the tuning process. You should bring your CYA up, but do it in batches so you don't overshoot. Use PoolMath to determine how much to add to get to 60. After a week measure CYA again and adjust as necessary.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    If you did add too much salt this is probably an indication that you are overestimating your pool volume. If this is the case you should adjust your pool volume estimate down when calculating how much chemical to add (CYA for example) or you will keep overshooting.
    Jun 2013
    Northern NJ
    123
    Well now I'm getting a 4000 average and a 3,600 instant My pool calculations are pretty much right on. Added the recommended salt even being more conservative. Are these readings ok? Ps my FC is 1.5
    38,470
    As long as the SWG is not complaining, they are fine.
    Jun 2013
    Northern NJ
    123
    Ok. Thanks much. I guess I'm starting to get a little OCD with all if these tests and numbers
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    FC is low, even for 40 CYA. Did you bring cya up yet? If so FC is very low.
    Jun 2013
    Northern NJ
    123
    Yes, brought cya up to about 70
    38,470
    Good point, now you should never be letting the FC get below 3ppm ... so try to set the SWG output to get you around 5ppm.
    Jun 2013
    Northern NJ
    123
    Yes, I also raised the salinity output from 70% to almost 80%
    38,470
    It is not a salinity output. The % is the amount of time that the SWG is generating FC.
    Jun 2013
    Northern NJ
    123
    I know. That's what I meant. % not output. Thanks
