Chlorine is .5 to 1
PH is 7.2
Alkalinity 30
Hardness is 50
Cyanuric is over 30 if I did it correctly
Definitely get the chlorine level up ASAP!
If it's just suspended dirt particles in the water, wait for the filter to catch up. But don't let the pool go green by letting FC dip too low while you wait!
If the pool is cloudy or greenish, then you need to perform the Shock Level And Maintain process - the SLAM. In your particular case, that means raising FC up to 12 and rechecking it and adding more to keep it at 12FC every couple hours.
It probably wouldn't hurt anything to actually start the SLAM; If you don't actually need it, it'll pass the three tests after one day; If you do, you'll have a day's head start.
Just curious, which test are you using to measure your chlorine? The OTO test (yellow color matching), DPD (pink color matching), or FAS-DPD (powder and drop test)?
Since you already have most of the tests that are included in the TF-100, you can get the FAS-DPD test here. The OTO test only measures total chlorine and only up to 5 ppm without much accuracy. You need a test that can measure FC and CC, and the FAS-DPD does that very accurately up to 50 ppm.
