Results 1 to 10 of 10
Thread: HELP! Is it safe to swim?
    MermaidMama's Avatar
    Aug 2013
    Pennsylvania
    158
    I added the pH Increaser exact amount it said. Mixed it in a big bucket and added it throughout the day yesterday, last being 9:00 at night. Swam at least 30 minutes every time to distribute. (We have no electric)
    Now my pH is at 8.2 and chlorine is back at zero. We are having a Fathers Day cookout with my whole family and swimming was a big part of it.
    I just Put my target chorine in at 5 and it said to add 62 oz bleach.
    Should I now add pH reducer. I have Otex pH Decreaser I can use. Can I slowly add it and stir it around with net and swimming?
    Is it safe for swimming????
    UGGGGHHHHH!!!!! Please help!
    MermaidMama
    18' Round x 52" Doughboy AGP ~ TF-100 Test Kit
    Powerline XP Pump 1.5 HP ~ AquaView 20" Sand Filter ~
    Aug 2013
    Pennsylvania
    158
    Re: HELP! Is it safe to swim?
    Adding my sig.
    MermaidMama
    Aquaview 20"Sand Filter
    8200 gallons ~ TF-100 Test Kit
    MermaidMama
    38,524
    Did you have your TA set in the now column when calculating you pH adjustment? The pH is for comfort, but you must get FC in the pool to be safe.
    Are you adding FC every day?
    Aug 2013
    Pennsylvania
    158
    I just added 15 oz pH reducer and 62 oz bleach. Three of us swam and made a whirl pool, lots of kicking for 45 minutes.
    pH test just said 7.5!!! Too good to be true?
    FC = 4
    CC = 0
    TC = 0
    TA = 110
    I can't wait till electric goes in tomorrow! (Fingers crossed)
    MermaidMama
    MermaidMama
    38,524
    Have you add CYA yet? If not, the FC will be lost to the sun in a few hours.
    Aug 2013
    Pennsylvania
    158
    Yes, I've been testing and did have TA set. I think with 0 CYA it's just eating up the chlorine. If you see above, I added and it's testing FC at 4 so I'm good now.
    Should I add a little more bleach before the picnic? Or just add it after?
    MermaidMama
    MermaidMama
    38,524
    With no CYA, 4ppm is pretty harsh already. Why have you not started the CYA dissolving?
    Aug 2013
    Pennsylvania
    158
    Jblizzle, I've been scared to add CYA since I have no electric and filter/return running. I've been swimming to disperse. Should I have? Too late now.
    MermaidMama
    MermaidMama
    Aug 2013
    Pennsylvania
    158
    Should I be using the dichlor for chlorine and have it raise CYA?
    Just tested. The chlorine is back at .5.
    Guess I'll add more bleach??
    MermaidMama
    MermaidMama
    38,524
    You could use Dichlor to slowly raise the CYA ... If you understand all the effects.
    Or put CYA in a sock tied to a noodle.
