Results 1 to 8 of 8
Thread: TF-100 missing blue scoop
    Jun 2014
    Grafton, MA
    2
    Hi,
    I took the cover off my pool yesterday and was hoping to test the water with TF-100 test kit so that I can start shocking the pool. However my kit is missing the little blue scoop for R-0870 powder. I contacted TFTestkits, but in the meantime is there any other way I can measure the powder so that I can perform the tests to avoid further delays?
    Andrew
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: TF-100 missing blue scoop
    Just find something you can use in the meantime to get out a scoop about the size of a wooden match tip. Perhaps a touch more, and it will be plenty close enough.
    Essential Links:
    38,463
    There is no real measuring required. You can not use too much powder, but too little can cause issues. Using the tip of a popsicle stick is likely more than enough.
    Mar 2014
    Atlanta, GA
    34
    I thought mine was missing too, and used a tiny little measuring spoon I had for a while. Then once, I was cleaning the inside of the plastic box and it fell out.
    New at pools. 23k Gallon pool - 36x17 ft grecian, vinyl. Pentair TA60 sand filter with new valve. Hayward superpump. Booster pump for Polaris 280C.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Welcome!
    It doesn't take very much - the tip of a popsicle stick or a wooden coffee stirrer will work as a scoop. After you mix it in, if there's one or two undissolved granules in the cylinder, you have enough powder.
    Jun 2014
    Grafton, MA
    2
    Thank you for the advice, I ended up using the end of a pen cap
    One other question if I may. I test the water in the house and grab a sample of pool water (from 18" underwater) in one of these bottles:
    http://www.walmart.com/ip/Mainstays-...ottle/14964974
    That should be fine to do right?
    Thanks.
    Richard320's Avatar
    Jan 2010
    19,051
    Sure. That ought to work great. Rinse it a couple times in the pool, then push it under upside down and when you right it under water, it will fill up with water from that depth.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I like to keep my arms dry so I use a 4' section of 1/2" ID PVC for sampling. Also lets me easily sample from about 3' deep in the deep end.
    Isolated Spa - 345 Gallons
