Thread: Auto-Filler Question: How long should it run for? Mine seems to be going almost 24/7
    keltose's Avatar
    May 2014
    Tucson, Arizona
    7
    New owner here, tried searching for info, but couldn't find what I was looking for. I have an auto-filler and the pool is staying at levels. I am in Tucson, so it's very hot and dry right now, so I expect evap, but even in late night or early morning, the auto-filler sprays just a tiny bit of water about every other second, like the waves of the pool make it bounce ever so slightly. I know it's just a little bit, of water, but am thinking this could add up. Shouldn't it be like the toilet and just float up and lock up until considerable drop occurs?
    Also, how much is normal evap for summer days?
    Thanks!
    11,640
    IG,Pebble
    Cartridge
    Pentair IntelliFlo VS-3050, 3HP
    Pool Pic
    Re: Auto-Filler Question: How long should it run for? Mine seems to be going almost
    In hot dry climates that behavior is normal. There are almost always some small waves in the pool, which will tend to turn the auto fill on/off like that.
    You can easily lose 1/8" of water, roughly a hundred gallons, a day in a hot dry climate. At the peak of the summer it could be noticeably more.
    keltose's Avatar
    May 2014
    Tucson, Arizona
    7
    Okay, thanks.
    11,640
    IG,Pebble
    Cartridge
    Pool Pic
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    try a low tech approach. Turn the auto filler off. You shouldn't be loosing much more than a 1/4 inch per day
    Factory Warranty Station for:
