Thread: Is it time to shock?
    Fayetteville, Arkansas
    220
    At the beginning of the season I established my CYA at 50 and the water was brilliant with no algae. We've had a lot of rain of late, so the current CYA level has been reduced to 30. I've adjusted my daily additions of bleach accordingly, but with the daily checks and addition of the prescribed amount of bleach, I'm getting green algae bloom, particularly on the shallow end floor.
    The other numbers are: Ph 7.8, CC 0.0, TA 80 FC 2.5 (this evening's reading, down from 4 yesterday evening after bleach was added). Target for the this CYA level is 4, according to the chart. I'm thinking of running the CYA back up to 50 with the corresponding FC target level like before after a shocking.
    So - what'd'ya say?
    Thanks everyone!
    20x40 30,000 gal IG Liner, Pentair II Sand
    Re: Is it time to shock?
    Yes, you need to shock. You can do that before or after raising the CYA level.
    At lower CYA levels it is easier for the FC to accidentally get too low.
