Results 1 to 11 of 11
Thread: Daily Muriatic Acid
    calypso's Avatar
    May 2014
    Pittsboro, NC
    8
    Daily Muriatic Acid
    New pool owners (stats below). I've read pool school and have been using Taylor k-2006 kit for a couple weeks. I resolved my CYA issue and was hoping the FC and pH would balance out too, but I'm still putting about 70 oz of bleach and 15 oz of Muriatic Acid every couple of days. My husband says we should keep the pump running all the time even though I have read here that four hours is plenty. He also likes the sound of running water, but I convinced him to keep the jet under the water. Am I right that this is causing our pH to stay high? I don't like dealing with the Muriatic Acid and would like to get our pH stabilized. Could the high pH be from the initial fill from our well water?
    Thanks!
    Today's results (typical)
    FC 1
    pH 8
    TA 180
    CYA 30
    11,000 gallon (16'x27'x54") Above Ground, Sand Dollar Top Mount Filter, Baquapure 2200 2 speed Pump 60 gallons/minute, bought used on craigslist & had a professional setup and install with new liner in 5/2014
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Daily Muriatic Acid
    Have you tested your well water?
    I see your TA is a bit high. That will come down over time if you keep adding acid to bring your pH down to 7.2, and let it climb back to 7.6 - 7.8.
    Other than that, you may need to SLAM your pool, since your typical FC is a bit low for your CYA. You could have something growing in your water, which would explain the high LC usage.
    Pool School.
    calypso's Avatar
    May 2014
    Pittsboro, NC
    8
    It's been years since we tested the well water. My husband says we have to tell them what we want tested.
    Two days after we filled the pool, it was green. I went to the pool store and got a shock treatment and started looking for answers and thankfully found your site. It was cal hypo. I shouldn't SLAM after that right? The water is clear and looks good.
    How much longer will I need to add Muriatic before I'm down in range? Anything else that can be keeping the pH high?
    Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    Yes, agitation of the water surface causes aeration and increases the speed of pH rise. Not a big deal but it does. I'm not sure about four hours, every pool is different and yours may well need more. It doesn't need 24/7 run time, but likely more than four. Start trimming that down and you will find out.
    You need to control the pH with testing and acid addition, so keep after it. Not critical in a vinyl pool, but you want it 7.8 or below. Anywhere from 7.2 up to there is good.
    Essential Links:
    Donldson's Avatar
    NW Ohio
    2,895
    Test the TA of your fill water. I have been having the same issue this year because I lost a lot of water over the winter and my well water TA is 650. Nothing you can do but keep adding acid until it stabilizes. Also get your FC up, it shouldn't ever drop below 2.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    When I suggested that you test your well water, I was meaning with your K-2006. That way you will know how water additions will affect your pool.
    calypso's Avatar
    May 2014
    Pittsboro, NC
    8
    Charlie - thanks - I don't know why I didn't think of that. I just tested the well water and our pH (8) and Total Alkalinity (240 or higher?) are high so it makes sense that I'm having a hard time getting it to stabilize. Makes sense that the CYA was 0 too. I'd only been buying a gallon of acid at a time, but I guess I'll go ahead and get a supply.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Are you using this sites "Pool Math" calculator to figure out how much acid to use to get from A to B ?? http://www.troublefreepool.com/calc.html
    You might only want to get two gallons of acid at a time. Depending on how far you have to drive to get it. Nice not to have too much sitting around the house once your pool pH stabilizes.
    Your first post has a CYA of 30 which is a little low but the post above says it's "0", I'm confused
    Solar Blanket, Well Water, Borax Added. 68
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    ph test wont read above 8 so that may mean you have ph 9 or more
    add required acid to bring from 8 to 7.5
    after one hour with pump running retest and repeat until you get a valid test result
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    calypso's Avatar
    May 2014
    Pittsboro, NC
    8
    sorry for the confusion - the last test results were for the well water as Charlie suggested. Glad I have the CYA resolved; now I'm just dealing with pH and Chlorine. We are definitely not close to stores with acid.
    I had been trying not to add more than once a day - should I go ahead and keep adding throughout the day?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You should be OK with the pump running to add acid every 30 to 60 minutes.
