Page 1 of 8 1234 ... LastLast
Results 1 to 20 of 143
Thread: New DIY Pool in Phoenix
    Jun 2013
    Phoenix, AZ
    130
    Hi guys, finally started our pool. Decided that we can get much more pool than if we go with a pool builder. Below is the plan that we are going with.
    Our backyard has been pretty empty for the past 5 years.
    Layout 2 weeks ago.
    Jun 2013
    Phoenix, AZ
    130
    Re: New DIY Pool in Phoenix
    We saved a lot of money hiring cheap, young help:
    Its tough working in 110 Degrees.
    But its amazing how fast they can work when you promise them an X-Box!
    Casey's Avatar
    SW PA
    10,428
    Oh man... that back yard is just BEGGING for a pool!!!
    Can't wait to see it completed!
    Jun 2013
    Phoenix, AZ
    130
    Jun 2013
    Phoenix, AZ
    130
    First major problem: Was at home when dig started but had to go to work. Wife was home when excavator finished. Excavator dug only one hole for a skimmer and it is in the wrong place. Memo to self and others: next time make sure pool designer marks on design where skimmers should go.
    Talked to plumber, red Xs mark where skimmers should go.
    That's me using the jackhammer digging a new hole for the skimmer.
    Jun 2013
    Phoenix, AZ
    130
    Question: Should the wrong skimmer hole be filled back up with dirt? Will ask plumber and shotcrete guys also.
    Jun 2013
    Phoenix, AZ
    130
    Gas came in yesterday. About a 190 feet run from the front of the house and under the driveway.
    Jun 2013
    Phoenix, AZ
    130
    To the side of the house and then to the pool equipment area, barbecue, and two fire woks.
    Won't be able to charge my Leaf in the garage for a couple of weeks until electric goes in the same trench and after first inspection.
    This will be a fun build to watch. You have a huge space for it.
    Mar 2014
    Las Vegas
    40
    I'm excited for this build!
    Jul 2009
    Gonzales, La
    220
    Quote Originally Posted by vudoo222 View Post
    No need to back fill the wrong skimmer area yet. Shot crete crew can add a piece of plywood to spray against. Then backfill when they are done. Looks good so far.
    15x36 Gunite w/Diamond Brite(Bahama Breeze plaster), 3.5-6', Pentair Easytouch Automation panel, Pentair 3HP VS pump, Pentair CNC 420 filter, Pentair 5G color changing light, Polaris 360 cleaner w/booster, Pentair IC-20 SWG
    My pool build
    http://www.troublefreepool.com/threa...ales-Louisiana
    Jun 2013
    Phoenix, AZ
    130
    Quote Originally Posted by 36racin View Post
    Thanks 36racin, just what I need to know.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    You know something?? I LOVE AZ. I think I will come visit you when you are done!
    I LOVE your hired help. He sure is a hard worker! LOL
    Kim
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Your pool is shaping up great.... BUT I LOVE YOUR NISSAN LEAF..... I've wanted one of those for so long... And I want a white one...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2013
    Phoenix, AZ
    130
    Hi Lacey, I love my Leaf. No maintenance, no fluids or belts to change ever. Quietest car you will ever drive. Have to be careful if you live in a hot climate like Phoenix, it will wear out the battery much quicker. I have lost about 18 percent capacity in 19 months. However, I drive a lot. I have put over 29,500 miles so far. If you live in a more moderate climate, the battery will last much longer.
    32K gallon 24'x41' IG, 8'x10' spa, mini pebble,
    Pentair equipment [Intellitouch I9, IC-60 SWG, 520 sq Clean + Clear Plus cartridge filter, 3 VS pumps(1 FX, 2 intelliflo)], Dolphin M5 cleaner.
    2 rain shears, 2 water shears, 2 blubbers, 4 laminars, water slide, rock waterfall.
    Jun 2014
    Plainfield, IL
    1
    Just curious, how much did the excavation cost? Nice Leaf by the way. I'm about to hit 30K miles on mine this week.
    Jun 2013
    Phoenix, AZ
    130
    Excavation $3712. Had another bid at 3500 but they weren't able to come out until next week.
    Jun 2013
    Phoenix, AZ
    130
    Juice for my Leaf:
    Plumbers are here today with all the pool equipment, will have more pics tomorrow of plumbing when they are done. By the way, we opted to not go with the in-floors. Will be getting the Dolphin M5.
    Looks like you went with Marshall.
    Great guy and I will be going with him when i do my own pool.
    Did you get your equipment from him as well?
    Did he find the subs for you?
    Will
  20. Back To Top    #20
    Jun 2013
    Phoenix, AZ
    130
    Spanky, you can PM me and I'll send you the list of subs I used. Yes we brought all our equipment from Marshall. His prices are pretty competitive and they will often match prices.
