Thread: New pool, new pool owner, now what?
    Taylorbay's Avatar
    Jun 2014
    Heiskell, TN
    17
    Hello, been reading as much as I can here, been reading Pool School. They put the pool up today, it's filling as I type, they'll be back tomorrow or Monday to get the pump going. I felt pretty good about being able to keep up a pool until I started reading and now I'm nervous as heck! I'm to take a water sample to the pool place where I purchased for pool school, I'm hoping they will teach me, but I'm still nervous.
    Do I need to go ahead and buy the TF-100 test kit? Do I need to buy bleach at the store? What else do I need?
    Thank you all in advance!
    AG, 15,000 gallon. Sand filter
    Installed today 6/14/14
    24' x 52" Artesian Heritage AG / 15,000 Gal
    19" Sand Filter, 1 H.P. Pump Combo
    Installed: June 2014
    Frog System, Hard Plumbed
    38,254
    Re: New pool, new pool owner, now what?
    Welcome to TFP!
    I would certainly order one of the recommended test kits, TF-100 is the best value. They may give you a kit, but it will be lacking.
    You certainly should put 2ppm of FC in the pool as soon as it is filled and maintain that. You also need to get 30-50ppm of stabilizer in the water.
    This is not as hard as it appears, so relax. Just realize that they most likely do not recommend the maintenance methods that we recommend. So take anything they "teach" you about chemistry with a grain of salt.
    Taylorbay's Avatar
    Jun 2014
    Heiskell, TN
    17
    Stabilizer - which is that please?
    Butterfly's Avatar
    South Carolina
    10,045
    ^^^ +1 what Jason said
    Don't be nervous - you got this, and you have all of us to help you!
    Welcome to TFP
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Taylorbay View Post
    Stabilizer is CYA (cyanuric acid) also sometimes called/sold as conditioner.
    The ingredients listed should show at least 96% cyanuric acid. Sold in pool section at wallyworld, big box stores & in pool stores.
    Hop over to Pool School and read the ABC's of Pool Water Chemistry: http://www.troublefreepool.com/conte...ater-chemistry
    Have you ordered the TF100 yet?
    Casey's Avatar
    SW PA
    10,427
    Welcome. You are going to have to go through our Pool School if you want to do TFPC.
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Chlorine CYA Chart
    Test Kit Comparison
    Recommended Levels
    PoolMath
    These links will get you started and as previously stated, our way and the Pool Store way is different. You should choose one or the other and not both. If you chose the Pool Store way and you ask questions here, you will more than likely end up wanting to rip your hair out and become frustrated. But please note, going the TFPC route will yield you these fabulous results... The choice, is yours of course!
