Results 1 to 7 of 7
Thread: Stairs in pool or outside
    May 2014
    Cin OH
    13
    I'm trying to figure out if the stairs go into the pool from outside or the stairs are inside the pool to get you out.
    Thanks
    1) The size of your pool in gallons: 1
    2) The type filter you have (sand, DE, cartridge): DE
    3) If your pool is an AG (above ground) or IG (in ground): Above Ground
    4) If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass: Vinyl
    5) If you know, tell us the size pump and the size (flow rate) of your filter: ???
    Casey's Avatar
    SW PA
    10,461
    Re: Stairs in pool or outside
    Those steps are for inside the pool.
    May 2014
    Cin OH
    13
    Thank you.
    I'll search for some setup instructions.
    May 2012
    Montville NJ
    545
    Those steps are built incorrectly. They are the same ones I have.
    They are for inside the pool. the handrails are on backwards, they should run from the top of the steps to the bottom.
    The short peices that you have sticking out over the stairs go the other way. They are used to anchor the steps to the deck. If you do not have a deck, then you have to purchase the exterior stair kit.
    This is how they should look.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Apr 2013
    Akron, NY
    40
    I have similar stairs. Here is a tip if you need to take them out for the winter. These stairs want to float. Instead of filling the frame with sand as the instructions state, I take 4 1 gallon jugs and fill them with sand and then water. Then I zip tie them to the frame inside the legs to weigh the stairs down.
    That way towards the end of the season I disconnect them and put them on the stairs and then it is easier to get the stairs out for the winter. I would also suggest drilling some more holes for water drainage. When the stairs are full of water they are heavy and take forever to drain.
    24 foot 54 inch AGP, 14.5k gallons, 1hp pump, 120 sq foot cartridge filter
    May 2012
    Montville NJ
    545
    If you want to get all fancy-like, they sell a weight kit for the stairs as well. If you look closely you can just see it in my picture. It is two large plastic weights that you fill with sand (or in my case, pea gravel - it does not escape) and then they clip to the sides of the stairs.
    Used bleach jugs are a lot cheaper though.
    -dave
    Zodiac Wahoo
    Casey's Avatar
    SW PA
    10,461
    Quote Originally Posted by phonedave View Post
    -dave
    I was wondering why those other steps looked a bit weird. Makes sense now, looking at yours.
