How to test high FC levels?
Jun 14, 2014
3
Houston
I am getting ready to do my first SLAM but my test kit only measures up to 5 on FC. I'm going to need to get around 24 for shock value, so can I use my kit to read that high? For example can I fill the sample halfway and just double my reading, a third and triple, etc.? Or does it not work like that and I need to get a better kit?
Thanks in advance.
Welcome to TFP!
It is possible to get some very rough approximations with that kit, +-5 at best, but it much easier and more efficient if you get a FAS-DPD chlorine test, which can measure up to 50 in steps of 0.5.
You need a TF100 or a K2006 test kit which can read FC levels up to 50ppm.
You can look at them here :lookhere: Test Kit Comparison
We recommend the TF100 because it's a better value for the money.
