Thread: When should I use recirculate?
    May 2014
    Burlington, NC
    45
    What application does the recirculate slot have on my multiport valve for the pool sand filter? Haven't ever used it and wondered what its purpose is.
    Thanks.
    18,000 gallon IG vinyl
    Hayward S220T sand filter, replaced sand 2013
    Sta-Rite pump, 1HP?
    New liner, 5/12; pool built in 1981;
    38,290
    Re: When should I use recirculate?
    You can use it if you need to repair the filter or in the middle of a SLAM when you can not backwash often enough.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    If you're clearing a swamp and you want to keep the chemicals circulating but you won't be around to backwash every hour as the filter loads up, you'd use recirculate.
