Thread: Taylor 9193 CYA View Tube
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Question Taylor 9193 CYA View Tube
    For using this Taylor 9193 CYA view tube , can I use my Taylor mixing tube that uses 7 ml of test water + 7 ml(K-2006) of reagent?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Taylor 9193 CYA View Tube
    No.
    I just filled mine to the rim and then poured it into a graduated cylinder. It holds 30 ml to the top. If you only had 14 ml of sample and low CYA, you wouldn't be able to get a reading.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Yeah, thanks. That's what I thought. I just re-tested my CYA and wanted to use this tube and realized that the volume of it was larger that my other tube. From what I gather, I have the same reagent needed but what is the required volume (ml) of the mixture? /edit/ still just 50/50?
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by DaneCE View Post
    I'd guess 15 ml of reagent and 15 ml of water, just in case it goes all the way to the top.
