Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Grading problems for a 24 ft round.
    Jun 2014
    Rock Hill South Carolina
    11
    Hi guys, new user here. I am currently trying to get the ground level for my pool and ran into a problem. The high end grade has been cut almost 4 foot and can't be lowered anymore because of the deck I want to put on that side. My question is, what is the best way to raise the low end (about a foot) and not have a sinking problems? The low side is far left and far center.
    jjwalker's Avatar
    S. Louisiana
    198
    Re: grading problems for a 30 ft round.
    Grade it some more and create a step down from your current deck....?
    Or raise it with the dirt (if there is any) from the excavation or bring in a truckload, and compact it with a tamper or plate compactor (rent it).... I would think you should be fine
    18x36 vinyl / sport pool 5.5' deep / 1.5hp Tri-Star 2spd / Hayward c3030 325 sqft cartridge / ~15k gal / TF100
    Casey's Avatar
    SW PA
    10,421
    Crusher, Crush n Run, 2a modified. It goes by a few different names in different regions but you can use this to add. Start out 4ft past the perimeter of the pool in 6" lifts and run a plate compactor over it. Add 6" lifts as you work your way up to level. As you go up, you'll get closer to the outside wall. You could also make a retaining wall to keep it in as the edges will slurry a bit in rain and look loose. This is the only way you can do it.
    Please keep us posted! I know pwrstrk did this. I was going to do it but didn't end up needing to.
    Quote Originally Posted by jjwalker View Post
    You can NOT! NOT! NOT! use dirt!
    Jun 2014
    11
    Thanks Casey, If I plant grass quickly do you think I can do without the retaining wall?
    Casey's Avatar
    SW PA
    10,421
    You should be able too! You need to do it ASAP so the grass can root it and help hold it. Put dirt around the slope and plant it.
    Take lots of pics!!! Would love to see how you progress and it turns out! We'll be here if you have any questions.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Yup disturbed dirt will not be sufficient to support the weight of your pool.... You need what Casey has mentioned, it does go by many names... I'm levelling at the moment and it sux....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2014
    11
    Natural rock for the wall and my cooler for the pool. Oh, and the crusher will be here this Monday or Tuesday!
    Jun 2014
    11
    Deck box for cleaning equipment and chemicals
    Casey's Avatar
    SW PA
    10,421
    My calendar says it's TUESDAY!
    Jun 2014
    11
    Level terra firma!
    Casey's Avatar
    SW PA
    10,421
    Great job! So glad it worked out for you!!! Can't wait to see it finished!
    Jun 2014
    11
    Thanks......I will post pics as I progress!
    24" round 54" Matrix, Liberty bd-track liner, 24" sta-right sand 2hp, 500 watt night light, 15 yr cover, liner pad and a Hayward Wanda the Whale pool cleaner.
    Jun 2014
    11
    I got the liner and rails put in also but it was to dark to take a picture. BTW...what's the best method for trimming the liner for the skimmer? I know that the pool should be about half way full but do you trim it even with the wall cut-out or cut a x pattern and overlap it?
    Jun 2014
    11
    Casey's Avatar
    SW PA
    10,421
    Re: Grading problems for a 24 ft round.
    You want to take the butterfly gasket and put it on the outside of the pool between the liner and pool wall. It's going to saddle the opening. Put the skimmer box up to the pool and add the screws through the face plate (the white plastic piece on the inside of the pool) and the liner, through the gasket and into the skimmer box. Once the box is on, cut the liner by tracing it with the utility knife and you should be good to go.
    Any problems or questions, just ask! The pool is looking good!
    Jun 2014
    11
    Nice...I would have guessed (wrong) that the liner went between the butterfly gasket and the pool wall. Thanks for the advise.
    Jun 2014
    11
    Fill day.
    Casey's Avatar
    SW PA
    10,421
    Are you swimming? Looks great!
    Jun 2014
    11
    Just started putting the chemicals in yesterday..... shooting for the fourth. Although, my daughter and wife have been using it already.
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,421
    Enjoy the rest of your summer and have a Happy 4th of July!
