Thread: Filter Gauge Reads 0 psi
    Apr 2014
    United States
    21
    Hi all, I've been reading other posts but still wanted to post my own. We finally got our new pool up and running. It's 27' round above ground, two speed pump (2 hp i believe), with cartridge filter and chlorine tablet holder thing When on high, the psi is between 10 and 15. However on low, the psi is at 0. I've read the gauges can be bad from the get go, but you'd think if that was my issue it would read 0 on high also. Everything seems to be fine - good seals, no air in system, great flow. Any ideas or suggestions? Thanks!
    Noob
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Filter Gauge Reads 0 psi
    Reading of 0 psi on low is normal. Got the same situation.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    You're good to go. It's normal.
