Thread: TF100 Chlorine Test Question
    Jun 2014
    Yardville, NJ
    2
    I have a quick question regarding the chlorine test. After I add the powder, I add a drop of R-0871. I swirl the water. It turns clear....if I wait 1 minute it starts to turn pink again. This continues to happen for a number of drops. Do I keep adding drops until the liquid stays clear after waiting and then take the measurement? Or is it the initial clear reading that tells me my FC? For instance, right now I am on drop 5 and it is still faintly pink if I wait for 1 minute or so.
    Thanks!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,620
    Re: TF100 Chlorine Test Question
    Turns clear, you're done without waiting. Waiting will usually let it turn back. Just a few seconds of swirling then add another drop if no change. Your problem is, if 1 drop is turning it clear-----ya' got dang little FC! .5 to be exact.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    When it stays clear for a few seconds while swirling it, that's it. It will always go back to pink if you wait long enough.
    Jun 2014
    Yardville, NJ
    2
    Roger that. Thanks guys.
