Thread: Hello All and Q about new construction!
    May 2014
    Houston
    1
    Hi All,
    Saw the site while looking for new construction gunite pool answers and thought it might be a great place to ask a question.
    I notice that the waterline tiles were installed directly on the gunite and before the pool has been plastered. I am concerned that it will leak between the plaster (that stops under the tile) and skimmer because the subcontractor did not pretreat or add any waterproof material before setting the tiles on the gunite.
    Is this a normal practice in construction? It seems to me that the gunite / thinset is not a waterproof material (but the plaster is -- but there is no plaster at the back of the waterline tiles and skimmer -- so what would prevent water leaking pass the tile, thinset, and gunite if only the plaster is the water barrier.
    Thanks in advance, mike
    Jan 2014
    Buckeye AZ
    807
    Re: Hello All and Q about new construction!
    the grout between the tiles?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    It is normal for tiles to be applied directly to the gunite. The tiles are waterproof, and the plaster and/or grout will waterproof between the tiles.
