Thread: Cloudy pool, DE question
    Hey guys,
    Day 13 of SLAM, and I think I would like to add DE to the filter. Pool has been blue and cloudy X 1 week.
    Here are my results from this AM
    FC 11
    CC 0.5 (maybe, was very light)
    Lost 1ppm overnight.
    My CYA is o.
    Quick question to verify DE process. So I think I am to put 1/4 cup DE in bucket with water and add slowly, repeating process until gauge raises 1?
    Once it raises up 1, then I stop adding DE...at what point do I backwash?
    After I backwash, Do I add DE again?
    Thanks!
    21' round 52" high AG pool with a 19" sand filter 1hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Cloudy pool, DE question
    Don't keep adding looking for the 1 psi rise. If you haven't seen it rise after a couple cups, stop.
    When the pressure rises 25% or the flow is noticeably reduced, then backwash. That is, you started at 15, the DE puts it to 16, when you get to 20, backwash. Whatever your particular values are. After you backwash, you will need to add DE again. Use the same amount you used the first time, no need to add it in stages again.
    You should raise the CYA level to at least 30. SLAMing is easier when CYA is 30 and you will lose less chlorine to sunlight.
    Ok, got It!
    Planning on getting the CYA up, however I have a leak in the pool that should be fixed by Monday. Guy couldn't come until the pool was cleared up some. Thank goodness it has been a very cloudy gloomy week here!
    Thanks a bunch (once again!!!)
