Results 1 to 8 of 8
Thread: Better Saltwater option..Venture or Matrix?
    tookiesmom07's Avatar
    May 2013
    Tennessee
    56
    We are looking at replacing our Intex with either a Sharkline Matrix or Venture. I know the Matrix has more resin parts than the Venture. And Matrix is good for a saltwater system. But would the Venture be fine too? It has some resin parts, but uprights are not. I don't want to buy a pool only to have it start rusting away when we go saltwater. Any opinions or advice would be extremely helpful!
    Intex Ultra-Frame 26x52 AGP (14,650 gal.)
    Intex Pump & Filter
    Re: Better Saltwater option..Venture or Matrix?
    I'll be interested to hear what the experts say, as I have the same question!
    May 2014
    SW, MO
    58
    First thing to check is the warranty, many non resin pools have warranties that are voided if you use a salt water system. Something to keep in mind is the coating is made to protect the metal from things like occasional splashes of water. It will not hold up if you have even a small leak, the salt water will eat through the coating and into the metal. You may get lucky and get 20 years out of your pool with no issues or you may ruin a wall in a few years, it's a risk. Go with resin if you want peace of mind and no worry about warranty with salt water.
    May 2013
    Tennessee
    56
    After reading the warranty on the Matrix, a saltwater system voids the warranty. So I guess we are back to searching for something we can do with a SWCG. Or just go BBB and buy the pool we really like. Just more to consider. Thanks for the responses.
    Intex Pump & Filter
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Fact of the matter is, Saltwater exasperates corrosion of metal.
    It really doesnt matter what the metal is protected with, over a period of time, the saltwater will eventually get to it.
    Speaking purely from a longeviety standpoint, you should get a resin AGP if you intend to use a SWG.
    Divin Dave,
    May 2013
    Tennessee
    56
    I thought I read the right warranty. There are like 6 listed on the Sharkline website. So, I have emailed Wilbar to ask exactly which of the Sharkline pools, if any, are saltwater compatible. Hopefully will have an answer in a day or two. I will post what I find out.
    Intex Pump & Filter
    Jul 2011
    West Monroe, La
    67
    We have a dealer installed matrix - they recommended a SWG system and warrantied it - out of the ones you listed it has the least amount of "metal" components. This is our 4th summer with no issues, make sure you use the right hardware around the perimiter of the pool (stainless).
    27'x54" Matrix Resin - 200lb Pentair sand filter - 1.5hp Pentair optiflow 2 speed pump - Aquatrol SWG - Gorilla Pad
    May 2013
    Tennessee
    56
    My reply email said Matrix, Navigator and Oceanic were the best options.
    Intex Pump & Filter
