Thread: Low cya, High FC
    Low cya, High FC
    Fc 10
    Alk 120
    ph 7.5
    Cya 15
    This pool is becoming a pain in the rear. I am on day 10 of shocking pool. I am no longer swamp green but a deep cloudy blue. My problem is my FC never seems to come down. So I don't think I am adding enough bleach during the day. I was using the test kit from Walmart but it only goes to 5, now using the test strips and those keep reading at 10 Fc. The reading never changes, I test about 3 times a day. 11am-3:30Pm-12am. I vacuum once a day before I go to work. With my cya low shouldn't I be losing clorine. Since I can't see bottom of pool I know the test can't be right. I ordered the tf100 today. What should I do until then Since I'm most likely not getting correct reading? When pool guys repaired my filter they used the zeote sand. Supposed to be better but who knows. I have next dose of cya dissolving in a sock in the skimmer. Since reading never changes I add 2 gallons of 8.5% bleach a day. Once at 11am and then at 4pm.
    AG 15x30 4 ft deep 12000 gal.
    Aqua Star 100lbs Sand Filter model fs019
    Installed june 2012
    Re: Low cya, High FC
    Order a testing kit. I tried to get by with strips for years. A good kit makes it so much easier. It took 5 days and $30 worth of bleach to clear our pool this year.
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    May 2014
    Lewisberry, PA
    93
    Hi zeroturn. I hope you find TFP to be a great resource. Congratulations on taking control of your pool and ordering a good test kit. It will enable you to take your pool back and on your way to crystal clear water. I have no doubt that one of the well knowledged moderators will be along shortly. You will find their advice to be priceless! In the meantime, I hope you took the time to research the site, go through pool school and browse the forums. It will give you a head start. Best advice I can give you right now is to be patient and wait until you can get some confident pool tests. Guessing with pool test strips or unreliable results will only get you frustrated and cause you more work,money and time!!
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
