Thread: How Many 4X8 Foam Board Insulators will I need??? Help Going to Buy in an Hour!!!
    Jun 2014
    Burbank
    12
    Building pool Sunday going to Buy the Foam Board I have 2 Questions I am terrible with figuring this out!
    1) How many 4 X 8 Insulation Boards do I need?
    Owens Corning Extruded Polystyrene Foam Board Insulation (Common: 0.5-in x 4-ft x 8-ft; Actual: 0.5-in x 4-ft x 8-ft)
    2. Is the .5inch thick kind enough?
    It is just so expensive!
    I want the insulators to go under the legs too.
    Thanks
    4742gal, AG, 9x18x52" Intex, vinyl, sand,1500gph, just purchased 6/1/2014, Going to be building SOON !! EXCITED!!
    May 2014
    san tan, az
    61
    Re: How Many 4X8 Foam Board Insulators will I need??? Help Going to Buy in an Hour!!!
    What size pool?
    18'x48" Intex Ultra-Frame (Grey), Intex 2150gph Sand Filter (#28647EG), Intex Krystal Clear SWCG (#54601EG), Hayward SP1091LX Dyna-Skim, Intex LED Light.
    Jun 2014
    Burbank
    12
    18X9x52
    jmcdtucson's Avatar
    Jun 2014
    317
    3 across, x 2 = 6 gets you 12x16. 2 more to do the last two feet. So 8 total?
    Jun 2014
    Lawrence KS
    2
    Don't forget the supports that extend out 2ft on each side (I'm guessing 2ft, can anyone verify. I have the same pool on order, going up as soon as I get it.). So at least 22x13. I have also read that using the 1.5 foam is best (comfort and protect the liner) and will accommodate the 2x12x15in (which is actually 1.5 thick and 11 1/4 wide) treated green wood under each brace. Simply cut a hole where the brace meets the foam and replace with wood.
    Intex 18x9x52 (New install)
    1200gph sand filter
    Salt Water
