Results 1 to 8 of 8
Thread: Get pool into shape
    May 2014
    Tea sd
    13
    Angry Get pool into shape
    Hi, I have been reading a lot on this forum and I am attempting to get chlorine to stay up.
    24' doughboy round pool
    14000 gallons
    Sand filter
    Here are my readings
    No chlorine
    Ch 350
    TA 150
    PH 7.2
    Cya 50
    The water is crystal clear
    I cannot keep the chlorine levels up
    I have been putting Clorox in daily for the last week
    What's next?
    I have the Taylor 100 test kit
    Thank you.
    Casey's Avatar
    SW PA
    10,461
    Re: Get pool into shape
    How much chlorine are you adding daily?
    Are you losing anything at night? Tonight would be a prime opportunity to do an Overnight FC Loss Test to see if you have anything growing in the pool.
    I would bring the pool to SLAM level right now and check it at 5am. There are only 2 things that consume chlorine and that is sun (which we eliminate in the OCLT and organics. If you lose FC tonight, you have critters in your water.
    May 2014
    Tea sd
    13
    Quote Originally Posted by Casey View Post
    I would check the levels before I would go to work and add maybe 1 to 2 gallons of bleach. When I get home I check it again and it will be around 2-3ppm.
    I'd let it sit overnight and the chlorine levels cc would be 0.
    Other times the cc would be 1.5.
    Basically the levels are all over the place.
    I will take your advice, and do that today.
    One other thing, what about changing my sand. Could I have algae in there? It would be the only place I could check?
    Thanks.
    Butterfly's Avatar
    South Carolina
    10,045
    You need to SLAM the pool. Follow the directions in Pool School to a T.
    http://www.troublefreepool.com/conte...tain-shockingl
    No need to change sand, but it might need a deep cleaning if it has not been done recently: http://www.troublefreepool.com/threa...-a-Sand-Filter
    Welcome to TFP
    You're done SLAMing when:
    May 2014
    Tea sd
    13
    Quote Originally Posted by Butterfly View Post
    Welcome to TFP
    Thanks again!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Cornhusker66 View Post
    Thanks again!
    You're welcome.
    The CH is at the top of the recommended level, so don't add any cal-hypo. What is the CH of your fill water?
    May 2014
    Tea sd
    13
    I was doing so good.....until the rains came!
    Don't get me wrong, we needed the rain.
    I was monitoring the chems every hour faithfully all day. Chlorine was doing well. Now I have so much water that the pool is spilling over the skimmer.
    I just checked my cya levels. It went down from 50 to 30. No chlorine either.
    Do I need to bring my cya levels up, before adjusting for chlorine?
    Doesn't this take a week?
    So frustrating.....
    Thanks for your help.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Any chance you have a layer of rain-ish water on top with lower CYA but the water closer to the bottom still has 50 CYA ? I remember seeing that a few times... maybe run the pump for a while and measure again, or find a way to take the sample from closer to the bottom of the pool.
    IIRC the usual practice when doing a SLAM with 0 CYA is :
    - add enough CYA to raise level to 30 and immediately target 10 FC
    - after a day or so assume the CYA is there and bump FC level appropriately (12 IIRC).
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
