Results 1 to 8 of 8
Thread: asking questions before I get in over my head
    Apr 2014
    monroe WI
    11
    hello all
    My wife and I just bought a house in the country. so we are trying this pool thing
    Info
    we live in Monroe WI and are setting out our pool over the next couple of weeks. Here is what I have so far
    Pool - 22'x52" intex ultra frame pool
    filter system is 2650 sand filter
    test kit TF-100 with stir system
    we so far bought CYA 8 lbs got two old socks
    16 gals of 10% bleach
    I have to have our well water tested for iron (if high I'm going to ask the fire chief if we can fill the pool)
    some questions I have so far after the ground is level and pool is up and filled, do I start running the pump, add CYA. Do I have to wait to start adding bleach or do I start right away?
    what level do I get the bleach at? do I have to SLAM or just get it to the maintaining level.
    I keep reading the school but still a little nervous
    Thanks
    Jeremiah Strese Southwest WI
    22' x 52" Intex AG 11400 gals (I guess)
    2650 intex sand filter TF-100 test kit
    Hopefully adding water by June 24 2014
    Casey's Avatar
    SW PA
    10,423
    Re: asking questions before I get in over my head
    Welcome and so nice to see you have been doing your home work!
    Once the pump is kicked on, you can add the CYA via sock. (I'm going to assume your pH and TA are fine)
    Shoot for a 30ppm and get a target FC of 4ppm. You can look at the Chlorine CYA Chart in Pool School for reference. If your water is clear and you have no CC's there is no reason to SLAM. You're going to have a fabulous summer!
    Apr 2014
    monroe WI
    11
    That great news. I will be doing some water tests before we fill next week.
    Are pool stores the olny place to get the water tested for medals?
    Never be in a pool store and I never want to be in a pool store.
    Casey's Avatar
    SW PA
    10,423
    You can have them test for metals there. They will probably run the whole gamet and try to sell you stuff and then you can just walk out and do the TFPC.
    Apr 2014
    monroe WI
    11
    When using the poolmath do use about 90% full on the size chart?
    Casey's Avatar
    SW PA
    10,423
    I'm not sure what you're asking?
    Apr 2014
    monroe WI
    11
    The intex box said 10400 gallons @ 90% full do I use this number or the poolmath number for total gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by hduc2005 View Post
    Use the 10400 as full.
    And welcome!
    Depending on how long it takes to fill your pool with the well, you might want to estimate how much water is in there and add 2 or 3 ppm FC every day as it's filling. Just pour it into the hose stream, maybe swish it around a little with the brush. If you can fill it in two days, don't bother. But some people have to go 6" at a time or whatever because of the well capacity and that could take long enough for algae to get a toehold.
