Results 1 to 16 of 16
Thread: Diving in...
    Jun 2014
    Durham
    10
    Question Diving in...
    Just recently won a long, drawn-out algae battle, and am ready to make the leap to the TFP method - so I don't have to fight that battle again. Full results from my new TF-100 test kit:
    FAC: .5 or less
    CC : .5 or less
    TA: 110
    CYA: 50
    CH: 525
    This is all pretty well in line with results from my last visit to the pool shop, with the exception of the calcium hardness. My result is more than double theirs; maybe I botched that test? Unfortunately, the last step in the algae battle (with the pool shop), was a copper algaecide. Shop test results show .9ppm copper remaining.
    So here's the big question: I'd love to start my first SLAM tonight, but I'm concerned about the copper level. Pool shop has always been very scary about shocking when I have Cu in there. Slam away, or deal with Cu first? Liner is vinyl - does that relieve some Cu/Cl concern?
    Thanks in advance; I plan to be a regular here!
    20 x 40 IG vinyl, grecian; roughly 24k gallons
    Haywood cartridge filter, 90 sq ft
    Kreepy Krauly Classic
    semi-wooded lot
    Casey's Avatar
    SW PA
    10,427
    Re: Diving in...
    Welcome!
    I'm not sure what Cu is but your CYA is 50 and your SLAM Is 20ppm. Your target after your SLAM is 6ppm and never to go below 4ppm.
    Quick question though... Why are we SLAMing? Is the pool green and cloudy again?
    And if you're concerned with copper, you can bring it down with water replacement. And don't use any more algaecides!
    Jun 2014
    Durham
    10
    Re: Diving in...
    Thanks for the quick reply! Pool is still cloudy - slowly clearing over the past week since i replace cartridge with a brand new one. It also has not held chlorine at all. After conventional, pool-store shocks it would be back to near 0 by the next morning.
    Sorry - when I said Cu I was referring to copper. Pool shop has always been hesitant about shocking/adding chlorine when I had copper showing up.
    semi-wooded lot
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Diving in...
    If you raise FC to slam level with copper in there like that, there is a risk of your water turning green. Clear, but still green.
    THe only way to remove the copper unfortunately, is to replace water until the copper level is much lower. Somewhere to less than .3 if I recall.
    There are copper sequestrants, but they are bandaids.
    Most algaecides contain copper. Some heater plumbing contains copper.... pennies are made of copper.
    Do you know how the copper got in there?
    Divin Dave,
    Jun 2014
    Durham
    10
    Re: Diving in...
    Yep. Copper-based algaecide. Won't make that mistake again, but that's where I am. Saw some info about CuLator here; maybe that's what I'll need to find...
    semi-wooded lot
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,982
    Re: Diving in...
    I say do it. We never trust any other pool store results, why do we suddenly trust the copper test? If the water turns green, you need a sequestrant. End of story.
    A compromise would be to drain some water to both lower the CYA and the high CH (betcha they had you using Cal-hypo shock by the bucket) to 30ish and 300ish respectively and then SLAM.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Diving in...
    Richard has a good point !
    Divin Dave,
    Jun 2014
    Durham
    10
    Re: Diving in...
    Thanks guys. I'm gonna pull the trigger. Before and after pix coming soon...
    semi-wooded lot
    Casey's Avatar
    SW PA
    10,427
    Re: Diving in...
    Jun 2014
    Durham
    10
    semi-wooded lot
    Jun 2014
    Durham
    10
    Re: Diving in...
    Costly day to do my slam yesterday - very sunny. But seemed to go well. Only a trace of CCs this morning, but it did drop from about 22 to 18 FAC. I didn't beat the sun this morning, so some may have cooked off. Thinking of letting it settle in today, to let the kids swim for daughter's birthday. Thoughts?
    semi-wooded lot
    Jun 2014
    Durham
    10
    Re: Diving in...
    Thanks to all for the guidance! I think I'm getting it "dialed in", and am thrilled with the results. Sparkling! Probably the clearest it's ever been. Full battery of tests this morning, and I'm happy. I don't think I've EVER had 6ppm of FC in the morning!
    FC: 6
    CC: 0
    CH: 425
    TA: 100
    CYA: 55
    Will upload after pix later; getting upload failures now...
    semi-wooded lot
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Diving in...
    Awesome! THanks for checkign back in.
    the best way to post unlimited pics is thorugh photobucket.
    upload pics to photobucket
    click to full size the pics you want to post
    On the right, is 3 lines of code
    click on the code with IMG beside it. the code will be copied
    come back here and paste the code.
    The pic will show up when you post your message.
    Cant wait to see them!
    Divin Dave,
    Casey's Avatar
    SW PA
    10,427
    Re: Diving in...
    Hi Todd, Have you passed the Overnight FC Loss Test?
    Can't wait to see your updated pics. It is very important, once you pass the Overnight FC Loss Test
    that you keep your FC in line with your CYA as outlined here Chlorine CYA Chart. It will keep any and all algae away.
    We hope you enjoy your trouble free pool this summer. That is our number one goal here at TFP.
    daytoman's Avatar
    Jun 2013
    Oklahoma City / OK
    78
    Re: Diving in...
    Wow, this is exactly how my pool looks as of tonight. Starting SLAM tomorrow, hopefully, if my cya is low enough. Pool is refilling now.
    I'm excited to hear you are getting good results. Cant wait for the pics.
    Jun 2014
    Durham
    10
    Re: Diving in...
    "After" pix. Thanks for the photobucket tip, Dave!
    @Casey - I have not done a true and honest overnight test yet, but I'm happy with my morning FC levels now. I will do it tonight. I'm a bit concerned about accuracy, for my pool, however. With the semi-wooded lot I get so much organic junk, even over night, I'm not sure I can get an honest result. But I'll give it a shot. I am also doing my best to adjust FC each evening, to keep it in the target range for my CYA.
    semi-wooded lot
