Thread: CH - how low before adding calcium chloride?
    efm1972's Avatar
    Jul 2012
    Philadelphia, PA
    19
    TFP's recommend CH level for a plaster pool is 250 - 350 ppm. My current readings are:
    FC - 3.5
    CC - 0.0
    pH - 7.5
    Alk - 80
    CH - 225
    CYA - 30
    Last year, CH was about 250 all season. This year I have been at 225. I test using Talor test kit (K-2006).
    This is my 3rd season with pool. Pool was installed in May 2012. Water and plaster look good.
    I haven't done anything at this point, but wanted to know if I should be worried and start to get the CH above 250.
    Thanks
    18,500 gallons, DE filter, IG
    Onyx Ansylbrite (colored) plaster
    Jandy Pump 1.0 HP, Zodiac Filter (flow rate = 120 gpm)
    Installed May 2012
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,424
    Re: CH - how low before adding calcium chloride?
    I would go ahead and raise it up to 250. You may just want to get a couple of bags of cal-hypo since you don't have to raise it very much.
    Love TFP? Become a
    TFP Supporter!
