Results 1 to 8 of 8
Thread: Pentair Superflo 2 Speed Pump Question
    May 2008
    Louisville,KY
    59
    On the 2 speed pumps that have the built in high low switch does the unit have to be powered off to switch speeds. Setting up a pump through a timer and have a house full of teenagers and i want to be sure to cover any scenario that may arise. This is the unit that I will be purchasing. Thanks
    http://www.inyopools.com/Products/03501145035273.htm
    16x32 IG vinyl
    24000 gallons
    Hayward super pump 1.5HP
    Hayward Pro Series Filter S244T
    3 returns, bottom drain, skimmer
    38,295
    Re: Pentair Superflo 2 Speed Pump Question
    No. You can change speeds any time.
    May 2008
    Louisville,KY
    59
    Thanks jbizzle. I notice in your sig that might be the same pump you have. Do you see any possible issues I may have with this setup? All of my piping is 1 1/2inch The total distance of my suction side piping is around 50 feet. I do have a slide on a separate return that I keep shut off at the pump. On my current setup if I want to increase water flow to the slide I just reduce flow to the return a little. I believe that the current single speed 1.5 hp pump I have is just too strong for my filter. I just installed a new pressure gauge on the filter and it only shows pressure at 14psi. Never checked flow rate at returns, but it is pretty rapid. Thanks, Tommy
    16x32 IG vinyl
    24000 gallons
    Sep 2013
    DFW Metroplex
    119
    Quote Originally Posted by tnewton7 View Post
    I am not sure if this pump has a built in high low switch? are you sure?
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
    May 2009
    Youngsville NC
    395
    Yes it does - jbizzle owns this pump and has often commented this is a great pump for getting into 2 speed because of the builtin switch. I'm thinking of changing over to it when my current 1.5 HP energy effiicent Superflo needs replacement.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    mas985's Avatar
    Pleasanton, CA
    11,737
    Not all SuperFlo's sold on the internet have a switch so it is a good idea to check with the supplier first.
    Mark
    May 2008
    Louisville,KY
    59
    Thanks for the heads up.Contacted INYO POOLS and it is available for purchase for the low, low price of $32.99. Looks like I will just add a 20 amp SPDT toggle switch to my timer.
    16x32 IG vinyl
    24000 gallons
    38,295
    Easy to use a household 3-way light switch as well.
