Results 1 to 10 of 10
Thread: Looking for some opinions.
    Jun 2014
    Dorr, MI
    3
    Hi guys, I'm going to install a 24' AG pool and am having a hard time deciding where. The conflict lies between sun or shade and how close/ far it will be from my house. Do you guys prefer sun or does that not really matter? I will have a heater installed too if that helps. Any help is appreciated! Thanks guys.
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Hi Phill. Welcome to the forum! Looking forward to seeing more pictures of your build.
    My choice would be to put it in the sun! It feels great to relax in the pool with the sun on you, and just dunk yourself under when it gets too hot!
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    Jun 2014
    Dorr, MI
    3
    Re: Looking for some opinions.
    Thanks for the input nedchavez! I will be posting a lot of pics as I go.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    2nd vote for sun! but i do prefer having the surrounding deck attached to my living deck right off the house. keeps everyone from having to trek through grass to get inside and vice versa.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jun 2014
    Dorr, MI
    3
    Thanks for the tip, Northern! I wanted to attach the living deck to the deck that's going around the pool too. I think it would look awesome. The only problem with that is if it's close enough to the house to attach the two, then it'll be in the shade. There lies the dilemma haha. Thanks again for the help.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    SUN! You can always put up an umbrella for shade if you need/want it. Deck---------maybe a wide walkway of stone to the pool deck? It could be done up really nice with some thought.
    Kim
    nedchavez's Avatar
    Jun 2012
    111
    I don't think Phill's ever gonna put that pool up........I think he's scared of the water!
    DeeMac's Avatar
    May 2012
    Munster, IN
    123
    Another vote for sun !
    16 x 34 inground vinyl pool
    Hayward 1 hp super pump
    200s Hayward Sand filter
    May 2014
    Lewisberry, PA
    93
    My two cents....... I would go with optimum placement of the pool over whether it is in the sun or shade. Sounds like it would be in both sun and shade if you did. Best of both worlds! Only drawback would be debris from the tree's. Good luck with the pool!
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
    May 2014
    Worcester, MA
    29
    Both. How about putting it where there will be a combination of sun and shade if possible? I like the idea of it being off the existing house deck, but if you do put it further from the house
    would definitely do as mentioned and put in a walkway of some kind with a deck area at the pool. Good luck.
    John
    IG 33K Gallons 20'X40', Hayward Pro Series Sand Filter S310T2 (zeolite), Pentair Intelliflo 3HP SVRS Pump
