Thread: Sand filter and chlorine burn rate
    sam03v's Avatar
    Mar 2013
    north florida
    52
    This may be a dumb question: If organic matter in the pool eats chlorine and the sand filter catches organic matter, will a dirty sand filter (say one that hasn't had the sand cleaned in 5 years) increase the burn rate of chlorine as the water moves through it? I suppose it must, but after awhile the stuff trapped in the filter eventually stops eating the chlorine, but then it keeps piling on so who knows...It's just a thought my brain cell had while I was doing the SLAM to my pool.
    24000 gallon, 18' x 36' IG with deep end, vinyl, built 1986, new liner 2012,
    3/4 hp uprated 2 spd on hayward super pump
    1.5" dia lines, sand filter, polaris 360
    TF-100 test kit
    Re: Sand filter and chlorine burn rate
    Backwashing the filter should remove whatever is in it. Very little accumulates long term, and none of that continues consuming chlorine after a week or two.
    38,285
    If you are concerned: How to Clean Sand Filter
    sam03v's Avatar
    Mar 2013
    north florida
    52
    Thanks. I'm going to clean the sand soon. I saw a YouTube video that showed the procedure and I'm very curious to see what's in there.
    TF-100 test kit
